RPI Designs C7 Corvette aFe Control Rear Toe Link AC-460401006A
Platinum Supporting Vendor
2014-2016 C7 Corvette aFe Control Rear Toe Link AC-460401006A
aFe Control is proud to release the PFADT Series, Adjustable Toe Links for the 2014-2016 Chevrolet Corvette C7. From the factory, the rear of the C7 Corvette does not allow for toe adjustment, which is crucial for improved handling, and overall vehicle stability, especially on high horsepower models like the Z06. The Pfadt Series Adjustable Toe Links are made in the USA from 0.049” wall 304 Stainless Steel, and are TIG welded for added strength and feature 5/8” Teflon-lined rod ends, CNC machined 4130 zinc plated studs, and 6061-T6 misalignment spacers for unparalleled strength. The turnbuckle style link allows for precise, fine tuning, while major adjustments can be accomplished through the zinc plated indexable toe-plate eccentrics. Designed as a direct fit all necessary hardware is included. Bolt a set on today and regain traction and confidence in your C7 Corvette.
aFe Control Suspension products are engineered and manufactured in our Corona, California manufacturing facility.
Features & Benefits
• Turnbuckle style link allows for precise, fine-tuning
• Indexed toe plates accommodate major adjustments
• TIG Welded, 0.049” wall 304 stainless steel tubing
• Heavy duty 5/8” Teflon-lined rod ends
• CNC machined 4130 zinc plated studs and 6061-T6 spacers
Item # AC-460401006A
Website Link : http://www.rpidesigns.com/shop/item....ac-460401006a/
Features & Benefits
__________________
