Runs Flats did job today!
Received 3,439 Likes
Let me tell you the story and I need advice. I was 66 miles from home out in the middle of no where today. Going down the highway at 55 Mph and BANG! Ran over some junk in the road right over a rise. Clank, clank, clank, ratatatat. I pulled over and had my wife look at the tire as I slowly rolled the tire. She said STOP! I opened the door and went out to look at the rear right and it had this god awful hook, spike, iron grotesque piece of metal right in the center tread area. We heard the tire hissing away. I went in and looked at the DIC and pulled up the tire pressure. At that time it was 18. And then in a matter of about one minute it counted down to 0. So we got back in the car and I set the cruise control for 55. I stopped couple of miles down the road and took a look. It looked a little flat looking but the sidewalls were holding up enough. Went another few miles and checked again. It was doing its job. So we finally got home. Hooray!
Now the question. I will call service at my dealer tomorrow. Should I let them pick it up with a tow service if that is what they want to do? I am Leery of that. Should I drive the 5 miles over there? Or just wait and see what they have to say?
As we were driving home. I had my wife call the Chevy Road Service and they wanted to have me schedule it with the dealer for 10:30 AM delivery tomorrow. Ok with that, but they wanted to have it towed. I declined for now and said I would deal with this issue in the morning. I don't want the car banged up during a tow job. I know all you guys and gals get that for sure.
So my question is this. How should I proceed with this? That tire is not repairable. Take my word for it. The car has 9,834 miles on it and I imagine they can just replace the OEM Michelin runflat. I have a base car by the way. Or should I just buy a new set of tires I planned to buy when these wore out. Here is what I was going to buy.
All season for me and want run flats again. It would have been hours and hours before any rescue service would have go to me. This episode made a believer out of us.
Mitchelin Pilot Sport A/S Plus ZP (Run flats for base stingray)
Just take the wheel to a local shop like Discount Tire or something like that. Unless you have the added tire warranty then just ask them if you can bring just the wheel in if you're that worried. If it's their truck (flatbed) they'll be able to load it up fine without damaging it.
The following 2 users liked this post by IELAC7:
joemessman (05-25-2016),
Rebel Yell (05-25-2016)
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
I'm not sure how much tread is left on the other three tires, but I would guess w. almost 10K miles on the tires, you may be half way thru the lifespan of the other three. It is, however, a base car and the tires may not be as aggressive a compound (read: shorter lifespan) as some of the other car models like Z51 suspension. Someone will chime in and tell you so, or that it's not the case. Or, you could buy a $2 mechanical tread depth gauge and walk around your car and see how much tread is left on the three tires.
Reason I suggest the above is because if there's a lot of tread left, unless you really want A/S tires right now (and I can understand it for your climate, Portland, OR), it may make sense to buy one new tire, and use it until the other three get down to 4/32nds (2/32nds is the legal number, but 4/32nds is usually a good depth to change due to less traction in the wet). Then, dump the three tires, and possibly sell the fourth, newer tire for a few dollars ($50? maybe), and get the A/S tires.
Even tho you put 66 or so miles on the runflat tire getting it home, it may still be ok to drive it to a store, or the dealer. Or, as suggested above, you could remove the tire/wheel yourself and bring it to a Discount Tire. A search I did doesn't show any Discount Tire stores in Portland proper, but all around the city. Here's the page: http://stores.discounttire.com/or/clackamas/orp-04/
Good luck with it!
Good luck with it!
If you have the right correct lifting equipment (lift puck, low profile jack, proper jack stand) and you are comfortable enough to remove the wheel AND can lift the wheel into your other car (assumes you have a trunk large enough) I would bring it to a tire place like Discount Tires or Les Scwab.
You should absoluetely call around to find out price and availability BEFORE bought you bring in your wheel. I would also find out if they have the equipment AND experience to replace a run flat tire, not just everyone can replace a run flat.
I would not have it towed if you believe the tire is unrepairable. Towing it is a risk I would avoid at as long as possible.
Once you deem the tire is unrepairable, you can drive it all over the place (50 or a hundred, or some have reported over five hundred). You can drive it on a ruined RF longer than you might imagine. It's not like you are saving the tire for something.
Heck, even if the bead is broken, you can drive it a very long way.
Unfortunately I don't have the right tools to remove the tire. I assume that the tire is not a warranty item and that GM would replace it. So if that is the case I think I will just drive it over to Discount Tire and get it replaced. That tire had pretty good tread left.
Anyway, keep the suggestions coming.
The chances that OUR tires are "in stock" ANYWHERE are slim to none. RF, NonRF, it really doesn't make a difference. Our tire size(s) are rare.
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
Since the tire needs to be replaced why not drive the car to wherever you are going to get two new rear tires. With that many miles I would get a match set versus driving on one half worn. Since I have an air compressor I would also fill the tire before startig but as long as you drive slowly probably not needed.
Just my opinion.
Glad the run flats saved the day!
Just my opinion.
Just my opinion.
Received 19,307 Likes
'20-'21-'22-'23-'24
I put new tires on my 2015 C7 Stingray Base and because of the size, it took one week to get the tires in stock to the Discount Tire store.
First of all thanks for all your input. Here is what I decided. I am just going replace the tire. The left rear has plenty of tread left. My dealer can have the tire in today. I am just going to drive it over. Only 5 miles. Not worth the worry of having it towed! I have had poor experiences doing that in the past.
Thanks for posting your experience.
The dealer won't do it. They will farm it out to a tire store. Same problem here. Except I was 100 miles from Phoenix. Drove in to a Good Year store, and they replaced under warranty for $100. Take a good picture of rim before it goes to tire store. That way you will know if the rim is damaged by them, just in case it is damaged by them.
