C7 Memory Seat Problem
I have a 2016 Stingray 2LT and am having a small problem setting the seat memory. I adjust the seat to the position I want, press and release the "Set" button, then immediately press and hold the "1" button. While I am holding the "1" button the seat moves to a new position but the "two beeps" do not occur.. If I then readjust the seat position manually and repeat the memory set process it will terminate normally and sound the two beeps. Is anyone else experiencing this problem or am I doing something wrong?
carjo (07-21-2016)
Either change fobs or press the #2 button.
This is the answer, After you have everything set, Mirrors, steering column and seat, press both Set and 1 at the same time and it will remember all those settings.
You can then change the settings and set number 2.
I set number 2 with the steering up and forward. This makes it easy to move it out of the way if you want.
I had this problem the other day and called to make an appointment at the dealers. I read this post and even though I have had my memory seat set for 10 months, I tried it. And it worked. Thanks. I can't understand why it took 10 months for it to occur but it works great now.
If pressing both buttons together works, great! The manual says press set button followed quickly by button 1 or 2 or exit. That's always worked for me but you have to be fast. The acceptable time between buttons is very brief. I sometimes make changes on mine so I use it with some frequency. My wife can't seem to do it quickly enough. I've stood outside the car with the window down and made the changes for her.
E-Ray, 3LZ, ZER, LIFT
Received 9,624 Likes
