Z06 Oil Separator Canister on Intake Tube?
In the following pictures, the stock intake on the Z06 has a small canister on the bottom side of the intake tube that has a hose coming from the Dry Sump Oil Tank. Is the purpose of this canister to separate any oil mist from the vent of the Oil Tank to the Intake Tube? If yes, does this canister have to be emptied from time to time? If no, what is the purpose of this canister and does it require any maintenance?
What model year Z06 is this?
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
These are used on many cars to reduce intake air pulses mostly for noise reduction but can have other benefits. You can google for details.
RocksZC7 (07-16-2016)
My 2015 Z06 has it and I wondered what it did. I guess now I know .
I assume that since the LT4 has it that the LT1 also has it since it basically has the same intake design !
JerryU, your guess about being a Helmholtz Resonator is probably correct. Any idea why GM would connect the Dry Sump Tank to the resonator? Is it possible that the pulsing inside the resonator that is caused from sudden changes in mass flow (stepping on the gas) purges the oil tank of any blow-by vapor? Do any of the after market intake kits also include a resonator?
Perhaps they put the hose inlet there because of the pressure pulses. Thought the were mostly added to reduce intake noise. This is a pic of the one that was on my aFe cold air duct, which is a similar shape to the one on the OEM duct. It is hard to see since the radiator hood air duct covers it.
The appendage with the label "Plenty of Clearance" is on the aFe cold air duct, similar shape to the one on the OEM duct where the hose from the Dry Sump take and filtered air going to the crackcase for the PCV system insert. Made this pic for the PDF on the aFe install.
