I think I grenaded my torque tube...
I'm honestly not sure but with where the sound is coming from I think the bearing assembly in the torque tube gave up the proverbial ghost. The car still seems to run fine at idle but there is a definite squeaking and vibrating sound coming from roughly the center front of the cabin. Anyone else had one come apart on them? The damn car only has 9k miles on it...
Can you still drive the car?
Does the sound change with car speed?
Get up to speed, push in clutch and rev engine, does noise change with engine rpm or speed as car slows?
Maxie2U (08-10-2016)
My advise is take it to the dealer and have them check it. If they have to replace it ensure the have all current procedures on replacement.
Received 19,234 Likes
'20-'21-'22-'23-'24
I too would take it into the dealer and let them take a look at it. That really sucks that something like that would happen after only 9K miles.
Post a video from inside the cabin, door closed and no radio. Flaps closed too
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
Hmm, I have a Z51, M7 and drive it such that I use the HD suspension and hit the rev limited from time to time! On our rural roads next to corn fields that includes 3rd! Often shifting at 6000 rpm for fun out of 2nd for example.
Why would you get a Z51 and live with brake pads that dust so bad you have to clean the wheels every ~100 miles (I did for a year until I put on Carbotech 1521's) stickier large diameter front times that make "Chatter" worse on slow speed turns so you need to make "K" turns when it's below 45 F, deal with a dry sump and drive like a "Granny!?"
Only 73 so hope I don't get that old!
But agree going around the large fountain on the single lane road segment at the end of my street is not done at high rpm or high speed but the "g" force achieved is high and fun!
If you do this: Get up to speed, push in clutch and rev engine
and this happens: Sound does not change with speed but does change with engine RPM.
the problem isn't in the torque tube.
With the car in gear and the clutch pedal depressed, the shaft in the torque tube is turning at the speed of the transmission input shaft, not the engine.
What you may be hearing is the pilot bearing in the rear of the crankshaft. It supports the front end of the short shaft that goes through the clutch disc, which turns at the speed of the shaft in the torque tube. Noise in the pilot bearing would change as you rev the engine with the car in gear and the clutch pedal depressed.
That may be something I need to try. I assumed, probably incorrectly, that the clutch was at the rear of the torque tube with the rest of the transmission pack. Is this not the case? I won't be able to get to the car until tomorrow as it's in my storage garage at my grandparent's house(the thing let go on the dirt road to their house...talk about good timing i suppose). I'll get it out and let it roll a little and see what I can figure out given what you've told me. Thanks for the insight!
I had a similar sound I thought was the torque tube or somewhere in the drivetrain but it ended up being the high pressure fuel pump. You have a video clip of the sound?
The car also has a two piece dual mass flywheel. There were some early reports of the springs coming lose but again that would make a clicking sound not vibration as would the high pressure fuel pump.
Sounds like it definitely needs a trip to a dealer.
So...Just to update. Took it in to the dealership to have them diagnose it, after a day of them digging around it turns out it was a grenaded motor instead. Apparently it ate a rod bearing. On a positive note I'm getting a fresh crate motor under warranty...
Sorry about your troubles but sounds like they will get you back on the road soon.
