Painting Fuel Rail covers
These questions are for those of you who have painted their fuel rail covers. Thanks in advance for your replies.
1. Is a high temp paint needed?
2. Are they smoothed by a build up of primer, paint, top coat, or sanding?
3. Is a "flexible " primer required?
4. Is there an online store that sells quarts of paint in GM colors at discounted prices? Specifically Carbon Flash?
5. Did you paint or buy tape for the "CORVETTE" on the covers?
my advise would be to check out Steve Ray at Airbrush Inc. out of Owensboro, Kentucky. He has done both of my cars - one is 2007 C6 and still looks like new. The second one is a 2014 and still looks fantastic.
The following 2 users liked this post by Lapond:
AttyVette (01-05-2019),
Harley_Rider (08-04-2016)
Received 1,694 Likes
St. Jude Donor '15
I painted mine. I used rattle cans from automotivetouchup.com. No high heat paint, and they've held up fine for 8 months now. I didn't smooth mine out, you can go high build primer or sand them, it's too much for just paint or clear.
I started with a brush, but got a tip here to buy a paint pen for the lettering, that worked great. Then I clear coated them. There are more threads here about painting underhood parts if you search for it. It was a fun project for me, but I like stuff like that.
The following 2 users liked this post by Rooster OG:
gpruitt54 (06-17-2019),
^^^ Yours look GREAT!! Thanks again
Last edited by Steve Garrett; 08-10-2016 at 11:12 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
Moderator
High temp paint is not needed. After prepping the covers (cleaning thoroughly, sanding if you want "smoothies", etc. use a plastic adhesion promoter, then base coats, then clear. Automotivetouchup.com is a great source for all the different paints you need (plastic adhesion promoter, color matched base coat and clear coat).
I painted mine Torch Red with White lettering.
I have done many of these for other C7 owners. Also AW w Black letters.
You also use a Duplicolor product sold at Autozone. Cost is about $8.00 per can vs automotivetouchip.com @ $19.95 plus shipping costs.
bjones7131 (12-31-2018)
Received 19,274 Likes
'20-'21-'22-'23-'24
You can complete a DIY painting of the fuel rail covers for under $50.00. Be sure to clean the fuel rail covers thoroughly.
Acetone works great. Be sure to allow ample time for each coat to dry.
You can spend $300 if you want to or spend $50.00 and enjoy doing the project yourself.
Certainly any expense is at the discretion of the car owner.
Happy painting.
Happy painting.
The following 3 users liked this post by nmvettec7:
Paint Pens
Did mine a couple months ago and still holding up fine.
First soaked them in Dove soap overnight in the bath tub.
cleaned, dried, and wiped with alcohol.
Used Dupli-color automotive Adhesion promoter primer.
Painted with 3 coats of Rustoleum Acrylic Enamel spray paint
and finished with 3 Matte clear coats.
Didn't want a smooth shiny finish...
Cost about $18
Edit update: Didn't realize this "OP" post was so old...guess my suggestions didn't help him.
Cost about $18
orca1946 (12-31-2018)
Received 2,639 Likes
Cost about $18
Cost about $18
I did a set years ago on my C5 using Ford Red high-temp engine paint. I sanded them for a few hours with my pneumatic random orbital sander and got them smooth enough to where the first coat of primer made them smooth as a baby's behind. I primered them and sanded a couple more times after that then gave them a few coats of base color and cleared them with a few more coats. I wet-sanded between coats. Finally, I sanded them with increasingly finer sand paper and finished up with 2000 grit and polish.
Unsanded
One unsanded and one sanded
Both sanded
Primer applied
Color coat
Cleared
Polished and then I applied black acrylic letters
Unsanded
Both sanded
Primer applied
Color coat
Cleared
The following 5 users liked this post by Patches:
DECON BLUE (12-29-2020),
jimmie jam (01-01-2019),
Rebel Yell (12-31-2018),
Ronsta69 (09-14-2021)
Do the rail covers just pop off and back on ? Looks like they do when I flex them a bit, but don't want to force anything.....
How did you guys do the lettering? Paint the cover first, then mask and do the letters or did you use a paint pen? Seems like it would be hard to get the lettering perfect.
https://www.target.com/p/sharpie-174-paint-marker-black/-/A-52205544?ref=tgt_adv_XS000000&AFID=googl e_pla_df&fndsrc=tgtao&CPNG=PLA_Seasonal% 2BShopping&adgroup=SC_Seasonal&LID=70000 0001170770pgs&network=g&device=c&locatio n=9009899&gclsrc=aw.ds&ds_rl=1246978&ds_ rl=1246978&ds_rl=1246978&ref=tgt_adv_XS0 00000&AFID=google_pla_df&CPNG=PLA_Season al+Shopping&adgroup=SC_Seasonal&LID=7000 00001170770pgs&network=g&device=c&locati on=9009899&gclid=Cj0KCQiAmafhBRDUARIsACO KERM-KL3HX1lXXZ5DCsQLzPisr3lOO9kSAOhFWh4xysZ9 BA0OqR-9weIaAu2uEALw_wcB&gclsrc=aw.ds
laserjack (01-06-2019)
