TSB For rotors
TSB For rotors
I've tried searching but can't seem to locate the TSB that was posted regarding replacing the two piece rotor's on the Z51 if they are warped. My dealer said they know nothing about it and I can't seem to find it. Any help would be appreciated. Thanks
Foosh (08-11-2016)
Received 19,284 Likes
'20-'21-'22-'23-'24
Thanks for posting the link.
Replace OEM rotors/pad with a complete PowerStop kit for less than $425 shipped
http://www.powerstop.com/product/pow...oved%20Cooling
I already replaced the pads but hey if I can get new one piece rotors I'm sure they will help. I do not track my car so just street use.
Is this for all cars or only if you experience the vibration? I heard this eliminates the need for the cooling rings, which is a nice benefit I'd like to take advantage of.
Received 1,694 Likes
St. Jude Donor '15
They only do tsb's if you have a problem.
Were you experiencing a problem or did you just ask to have them inspected because of the TSB?
Slight shimmy at higher speeds. I don't track the car so it was Mainly highways speeds. Anywhere around 80-90 and a hard brake would cause a minor shimmy but they were still out of spec. I have 5000 miles on the car.
