Now available from SCP: C7 Corvette LT Series Malevolent 85KV Coil Pack Set
Supporting Vendor
St. Jude Donor '06-'07, '13, '15
C7 Corvette 2014-2016 GM LT Series Malevolent 85KV Coil Pack Set (Red)
So you need a little more spark for that LT engine in your Corvette? We have the answer at Southern Car Parts.
- Works with Current LT1's and LT4's
- Direct OEM replacement with a simple plug and play, won't void your factory warranty
- Improves fuel economy, throttle response, and idle characteristics.
- Increased engine efficiency with improved engine combustion
- Rated at 85K Volts, Malevolent coil packs offer nearly twice the voltage over the competition.
- Gains of up to 12hp have been seen with these coils over stock.
Average gain with no other changes is 6 to 8hp on an otherwise stock vehicle. Gains of up to 18hp have been experienced on heavily modified forced induction applications.
Fits 2014-Present GM LT Series Vehicles
Available here: C7 Corvette 2014-2016 GM LT Series Malevolent 85KV Coil Pack Set (Red)
