Constraint Report - August 11th for August 29th TPW
Moderator
The following are the constraints for this consensus cycle:
Stingray/Grand Sport:
GGA ............................. Black Rose Metallic ........................................ ................ 8% Less than 4 weeks/New Option Acceleration
1YW07/1YW67 & J56 ............... Grand Sport with J56 Brakes ........................................ ....... 60% Material Restriction
1YW07/1YW67 & J56 & J6F - ZLG ... Grand Sport with J56 Brakes, Red Calipers without Black Suede Design Pkg .... 0% Less than 4 weeks Material Restriction
1YW07/1YW67 & RUR - ZLG ......... Grand Sport with RUR wheels without Black Suede Design Pkg .................. 0% Material Restriction
1YW07/1YX07 & MEL & Z51/Z16 ..... Manual Transmission ........................................ ................ Not constrained this week
Z06:
No allocations this week
Z06:
Z06:
Z06:
Moderator
Unless you ordered the Black Suede Design Package, your GS order with Red Calipers won't be accepted by GM this week. The "Less than 4 weeks Material Restriction" means that the current constraint is expected to last for less than 4 weeks. However, I have seen these "Less than 4 weeks" last much longer than 4 weeks. It could be 50% next week or even not constrained. Really depends on just what is causing the material restriction. Sometimes a supply disruption is short lived, sometimes it can take a long time - just depends on what the issue is. Of course, we're not privy to what the problem is.
What's your current order status? If you are at 2000 or beyond, constraints do not impact you.
https://www.corvetteforum.com/forums...post1585921744
And no, at 3400, you are past the stage where constraints affect you.
Here's a link to a post that explains all the order codes. It's in one of the "Sticky" threads listed at the top of C7 General Discussion.
