GS Brake Pads
Supporting Vendor
St. Jude Donor '11,'13
Yes... the same.
If you want a quality aftermarket pad I recommend the Carbotech 1521 pad. A low dust pad that is rotor friendly and performs like OEM if not better under thresh hold braking and last longer. 100% non-corrosive dust will not harm your paint or wheels. This pad also contains NRS technology. Carbotech uses NRS technology on all C4, C5, C6 & C7 front and rear brake pads.
Here is a link to explain further what NRS technology is exactly: http://www.nrsbrakes.com
If interested let me know I will be happy to help you.
Carbotech™ Bobcat 1521™ The Carbotech Bobcat 1521™ is our high performance street compound that is our most successful compound. The Bobcat compound is known for its awesome release and modulation, along with unmatched rotor friendliness. Like our AX™ & XP™ line of compounds, Bobcat 1521™ is a Ceramic based friction material offering minimal rotor damage and non-corrosive dust. Bobcat 1521™ offers outstanding performance, even when cold, low dusting and low noise with an excellent initial bite. This compound’s virtually perfect linear torque production provides incredible braking force without ABS intervention. Bobcat 1521™ operating range starts out at ambient and goes up to 900°F. Bobcat 1521™ is suitable for ALL street cars, perfect for your tow vehicle, police cruiser. The Bobcat 1521™ compound has been found to last two-three times longer than OE pads you can purchase at a dealership or national retailer. That’s one of the beauties of Carbotech Ceramic brake compounds. Bobcat 1521™ is NOT recommended for any track use.
__________________
Adam Adelstein
Amp’D Autosport.com
Internet's largest retailer of Carbotech Performance Brake Pads.
PH:216-780-8825.
Email: sales@ampdautosport.com
Web Site & Direct ordering http://ampdautosport.com/
All major CC and Pay Pal accepted.
Check out Promo code:z28
Adam Adelstein
Amp’D Autosport.com
PH:216-780-8825.
Probably best to call up a dealership for this one to verify. If they tell you the wrong size and it doesn't fit, you can blame them on it.
I recommend Powerstop Z26's. Had my brand new OEM ones swapped out before I left the dealership while they were installing my Michelin Pilot Sport A/S 3+'s.
Tires:
4x Michelin Pilot Sport A/S 3+'s Tires: 1130$
Mount + Balance = $100
Brakes:
Front + Rear Powerstop Z26's: $120
Front Brake Swap: $110
Rear Brake swap: $110
Tires:
Brakes:
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
I will replace my planned GS pads as soon as I get the car with Carbotechs from Adam. The "made in US pads" cost more than the pads "made in China." But if you can't do the brake job yourself you'll probably pay the dealer more than the cost of the pads for the install.
The install on a Vette is easy to do yourself, I'll have my pads and install after I pick up the car.
i got my brake pads in but from a 2015 z06 for my GS
a 16 z06 shows a different part number..anyone know the difference?
I think there is a smidge different in size
