Z51 vs non-Z51/MRC vs No-MRC
Hi Forum!
Need your help in answering my questions. I own a gorgeous 2015 3LT Stingray with Z51 and MRC. I also own a bad back and not unless I drive with "touring mode" I cannot enjoy the car, but even in Touring mode it can't be a daily driver, which is what I want it to be because I love my car. Been doing a lot of reading on the Vette and several owners state that the suspension is softer in a "non-Z51/no MRC and a more comfortable ride as compared to the Z51-MRC package. Is that true? Also, if I purchase a base stingray with the performance exhaust option, will I still be able to switch between touring, sport, weather, and Eco modes or does the car have to come with MRC to enjoy those different driving modes?
In for the discussion, as I'm considering same on a C7 purchase......
vgcmd1962 (08-30-2016)
It depends upon what you want to enjoy with the driving modes: it won't adjust the suspension - you need MRSC to do so; but it will adjust steering effort, exhaust tone, traction control, throttle response.
The suspension on the base car without MSRC is quite a bit softer than Z51, especially w/o MSRC.
I have a Z51 with MRC and I recently drove a non-Z51 (with Z51 appearance package) and no MRC.
I'd say Touring mode in my car is very close to the other car. Perhaps with the smaller wheels the non-Z51 would be a touch softer.
Being an owner of a C7, you could probably go to a dealer and test drive a non-Z51.
Before you jump off the bridge, consider tire choices.
The Z51 comes with MPSS Run Flats. This is a compromise tire that will function OK on the street and on the track, but not great in either role.
For a street-only car, replacing this with a softer sidewall high performance tire can greatly reduce ride harshness without significantly reducing "real-world" handling.
This is about a $1500 change... if it doesn't meet your needs, you won't be too far in the hole.
The MR cars springs are about 35% softer than non-MR. It uses the shocks to compensate for lower rate as well as a monster rear stab bar. A non-MR car is certainly stiffer than the MR. I wouldn't even waste your time.
The mode select in a Non-MR car has no bearing on ride. It's strictly different throttle mapping, exhaust(if linked to drive mode), steering(if linked to drive mode), and gauge configuration(if linked to drive mode), and traction/stability control.
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
Hi Forum!
FWIW my Z51 non MRC but 45 mm vs 36 mm Bilstein shocks the stiffer Z51 springs, stiffer front sway bar then the base car and added rear sway bar (which the base car does not have) could not tell if it went over a quarter!
Some advocates of MRC make it sound like magic and that it can offset stiffer springs and stiffer/added sway bars-it can't! It can and definitely makes it stiffer in Sport and Track!
That said, have not seen definitive info on the softness of the base car with and without MRC. Assume it would be somewhat softer with MRC set at Touring but not sure how detectable. They key is the quality of the roads you travel on. In our flat, mostly good roads in Eastern SC it would not be a big difference, IMO. It no doubt would be better on a washboard road, which is what some post a video on an older Vette. Even using the Z51 "look alike" package with the lower profile tires is going in the direction of a "stiffer ride."
With my Z51 without MRC "I enjoy the benefits of the different modes," in: 1) steering feel, 2) throttle control, 3) NPP sound variations and 4) amount of traction control" - but the ride is always the same! I'm mostly in Sport.
Hi Forum!
I think a lot has to do with wheel diameter - I have 18/19s vs. the Z51 19/20s.
These have to make as big of a difference in ride feel /harshness as the run flat construction.
To help with curves I did put the Z51 sway bars on because of the lack of a rear on the base model. This doesn't affect the daily driving except when I use it on enthusiastic turns - straight line they are invisible.
I drive mostly in Touring mode.
I am considering a track day at the end od Sept. when I will use Sport and Track settings. I know those sway bars will be a benefit that day.
Lots of threads have debated this very point at length. I would say for regular street driving Z51 is definitely NOT needed. MRC is a nice to have and I would highly recommend on the street if you have Z51 if you like a smoother ride or drive on rough roads.
I have back pain and have owned and daily drove a 2014 non-z51 (no MRC) for a year and I have owned this '16 Non-Z51 with MRC for around a year now. Plus I have driven several non-MRC and MRC Z51s.
The non-z51 with mrc to ME is more tolerable than the non z-51 without it. Its not really 'softer' but it is much more controlled, especially on dips on the highway that would feel like a knife in my back on the upside. The shocks dont just get stiffer or softer in one setting or the other, they do a lot more many times a second. Perhaps not magic but close enough.
Since you already have an MRC Z51 I dont think you will happy with a non-Z51 with or without mrc. My biggest issue is getting in and out of the car sometimes, once I'm in even in sport mode its not a big deal - until I have to get out.
Tires will make some difference, instead of buying a new car I would find some repro 18/19" Z51 wheels an put some non-runflat all seasons on them and run the air pressure on the low side. That will be the best you can get unless you start swapping suspension components around. Corvette is a lightweight sports car and although some say a base C7 rides like a Buick, that is not true at all.
Depends what you are sensitive to as well, a friend of mine feels every bump and pebble in the road and it hurts him, me is the larger up and down suspension movements that get to me after a while. Its more that just suspension harshness too. My truck - drives like a truck - doesnt bother me much at all. But the huge cabin, pedal/steering wheel position and living room couch-like front seat and I can drive it all day even though it has the HD towing suspension and 20" tires.
But to answer your other question the 'mode' **** will still control the steering, exhaust (if you buy NPP naturally) and the throttle/auto trans mapping.
Good luck, back pain sucks.
There are quite a few threads on this... I've chimed in a few times, as one of the few who can authoritatively speak to this.
Short answer is definitely there is a significant difference. The coupe is more than capable, but is far softer across the board.
We bought the wife's '14 in June 2014, picked it up at the Museum, and drove nearly 4500 miles across country bringing it home. I drove it a lot on short and long drives, and it now has nearly 30,000 miles.
I bought my '16 Z51 MRC in September of last year, and again picked it up from the Museum and drove across country, a little over 4500 miles. Mine now has over 16,000 miles. I veto a lot of seat time in both.
Z51 in the softest mode is still far more firm than the coupe in the stiffest mode.
vgcmd1962 (09-03-2016)
Received 1,738 Likes
St. Jude Donor '15-'16,'18
Base car without Z51 or MRC and non runflat tires in 18/19 sizes will provide the "softest" ride. This is what I drive and I find it perfectly acceptable for road trips and cruising.
Hi Forum!
vgcmd1962 (09-05-2016)
The Z51 (with or without the MAG suspension) was too stiff a ride for my street/city driving..
I went with a base car 2LT WITH the adjustable MAG suspension...
Also changed out the run flats to Continental DWS all seasons..
PERFECT!
PERFECT!
You changed to another car? Did you lose $ by doing that? Your new car did come with the magnetic ride suspension? I've kind of lost hope. I love this car but the stiff ride is killing my back.
Which tires do you recommend?
