FOB 1 vs FOB 2
The fun came driving home 1500 miles with one FOB in my pocket, the other in a duffel in the hatch area. The computer was so confused. It would chime and honk seemingly randomly every time I got out of the car to warn me there was a FOB inside the car. Memory recall would randomly pick up one of the two FOBs and often just fail to recall. All that got sorted when I got home and put the second FOB inside the house.
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Hmm, can't be a gentleman and open the door and let her in first! Then the car thinks she's the driver!
In my case, the wife won't ride in the Vette unless I open her door and most important, since I make sure it is open fully so she clearly misses the side skirt, that I close it! She doesn't want to reach for the fully opened door!
My benefit is she doesn't have a key and doesn't drive the Vette! Oh she can drive a stick but feels if she put a scratch on the car I would get very mad! She's right! Works for me, although I keep trying to get her to use it at least once so if every needed she can deal with the clutch etc.
This thread reminds me of:
JerryU (06-08-2017)
Received 3,818 Likes
This is what I was told during museum delivery: The FOBs aren't (I think) distinguished by the little number. There's a big colored circle at the end of the FOB. For me at least that circle is yellow on one FOB, green on the other. There shouldn't be any need to mark or guess which FOB is which.
Well, my fob has a 4 on the key portion so I'm assuming this really has nothing to do with Driver 1 and 2.
For the folks that were asking, my 2LT Z51 displays the driver's fob number in the DIC area when the car is started. We had issues right after we got the car getting the memory seats programmed until I had my wife take her fob into the house, out of range of the car. I programmed mine and then put my fob inside while she programmed hers. The memory seats work perfectly now for each of us.
I still have an issue when we're both in the car. Occasionally it will pick up my wife's fob from her purse on the passenger side floor rather than my fob from my pants pocket right under the steering column. I'll start the car and immediately the seats will attempt to move to her position which is WAY too close and I have to quickly hit the memory buttons to abort and select my seat position. When this happens, the DIC is clearly showing the driver as fob 2 which is my wife's number.
We have the same problem when both our phones are in the car. Occasionally the Infotainment system will pair to her phone rather than mine.
Both issues are nothing more than a nuisance and only happen intermittently.
This discussion begs the question, with two key fobs near the car how do you command the car to recognize one key fob over the other. On the C5 all you had to do was push memory position # 1 or # 2. If the GS grabs key fob # 2, how do you tell it switch over to key fob # 1 and vice versa? It is stupid as h--- for the wife have to stand away from the car while I get into HER GS. This is predicated on the fact that the wife always has the fob on her possession (read as pocketbook) whereas I only have my fob when I am about to drive HER car (which is usually just to the gas station - lol). The Bluetooth connection is another design deficiency. When I am driving the GS and she is in the C5 following me, as her phone goes in and out of range I get a chime telling me of exactly what I don't need to know. No way to disable other than to have her turn off her Bluetooth. You would think GM would tie the Bluetooth connectivity to the one driving the car - fob # 1 or fob # 2 but instead it is tied whoever cell's signal gets to the car first. This is made worse by the wife never turning off her Bluetooth (My Chevrolet app) whereas her **** engineering husband worries about security and smartphone battery life. I can easily make this a NTSB safety issue since if her fob grabs the GS first, the drivers seat moves to a position that could break my knee caps (she is 5' and I am 6').
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,820 Likes
2015 C7 of the Year Finalist
Um... We all have keys to the corvettes! What do you mean "There isn't a key"? My 2014 has a key as do the 2015-17s.
OK, you nuked your post about the keys.
The car discerns which RKE is resident in the driver's seat and responds to that key. It doesn't matter if the wife gets in first and has her RKE in her pocket or purse. When you press the start button, the car looks for an RKE that is in the driver's area of the car and then responds to that RKE.
Elmer
Elmer
JerryU (08-14-2017)
Not so. The car (2017 GS) grabs whoever gets into the signal reception range first. The keyless entry field is 3 feet (although the RKE transmitter functions can work up to 197 feet away). The RKE system in no way differentiates who is sitting in the driver's seat, just who came into the entry sensor range first. RKW = remote keyless entry, there is no physical key per se. There is a (hidden) key in the fob but it is only for insertion into the key slot near the rear license plate which unlocks the car if power to the vehicle is lost. One inserts the entire fob into the steering column for programming transmitters to the vehicle of which there can be up to 8 transmitters. The steering column fob slot also handles fob signal interference and low fob battery states.
OK, you both are standing at the passenger door and the driver's door. She opens the door, you then open the driver's door. Who got tagged first?
My wife has been waiting for me in the car AFTER SHE opened the door using her RKE. I get in and start the car and I don't get my knees crushed into my chest with her settings on the memory.
Why then does the car check for an X, Y, Z location of the RKE when the start key is pressed? If it didn't, I'd get crushed with her seat settings.
See this: https://www.corvetteforum.com/forums...post1595091984
Elmer
#33
I bought another fob for extra backup, so it's #3.
I use #3 whenever I want to bump my reg Z51 into Z06 mode to get 650 hp...
Now that it's on the internet, then this must be absolutely true!!!
#34
There's been lots of posts about fob 1 and fob 2 and which is which. In actuality, neither of them is #1. Each fob is built with a unique identifier number inside one of its chips. This is used in 2 way communications with the car. The car has been programmed to respond to the unique number in your fob. Your fob is programmed to respond to a query by the car, identifying itself. All digital devises use unique identifiers.
Now when you program your seat, wheel, mirror settings you press SET and 1 and the computer associates unique fob number xyz with program number 1.
Where they are manufactured they assemble mass produced plastic covers from one factory with mass produced circuit boards from another factory. They aren't going to take the time, nor need to, to fit #1 circuit board into #1 plastic cover.
As I understand it, some cars do actually have a 1 or 2 on the fob. Possibly. But that would be for our visual reference rather than an electronic feature of the fob.
#35
#36
There is a RKE FOB that is associated with button #1 and button #2, thus, they are often referenced as FOB 1 & 2 but true, they're the same critter but have been associated with 2 different programs for memory.
Elmer
Elmer
#38
I'll explain what the numbers mean:
It was several months after I got my September 2013 built Z51 until a forum poster figured out what those key numbers mean. He deduced they were identifying marks in a two cavity die. It's a random chance on what you get!
Therefore:
25% get two 1s (what I had)
25% get two 2s
50% get a 1 and a 2.
However the most confusion for 25% of the folks who look, half of those who get a 1 & 2 have the first programed FOB be different than the key number!! For those folks, just swap keys!!! It would be foolish for GM to put numbers in a key that can be swapped- think about it!
In fact 25% of folks who had a 1 & 2 and by chance had them programmed in the correct order were a PIA! Kept telling others we didn't know what we were talking about, the keys were properly numbered. Some brought keys back to the dealer - who had no idea what was going on!!
#39
Scenario:
Wife opens passenger door and gets in the car with RKE FOB #2. This FOB is set to remember memory settings #2 and has a closer seat setting than RKE FOB #1.
Driver gets in driver's side with RKE FOB #1 in pocket.
When the car's "Start" button is pressed, what seat setting does the car go to? Seat position 2 (associated with RKE FOB #2) as it was the first RKE FOB recognized by the car during the unlocking procedure or does it go to the settings for the RKE FOB #1 in the pocket of the driver?
Video shows the car looks for the RKE FOB that is in the area of the driver's seat.
Video to prove: http://www.jaxvette.com/c7/IMG_1044.MOV
Elmer
Elmer
#40
As in a prior post I made on this thread some time ago, I'll explain what the numbers mean! I didn't discover the issue it was deduced by a poster in 2013 when there was lots of confusion. A Chevy Tech person that monitor the forum said after checking "with their sources" the numbers were not there for anything Chevy does it's for the manufacturer of the FOBs (or in this case actually the removable keys.)
Therefore:
25% get two 2s
Therefore:
25% get two 2s
Elmer
