How often to change the oil in a C7 "Z", mostly city driving?
Old 09-07-2016, 09:23 PM
gregkoz
5th Gear
gregkoz's Avatar
Default How often to change the oil in a C7 "Z", mostly city driving?
only 11 months old, had my 500 mile oil change then stored it last winter. since then, have put 2200 miles of mostly city driving to work and back. the oil "computer" says I have 12% remaining oil life. probably at the 3k point it thinks I should change oil. what do you all think is a good schedule to follow?
Popular Reply
09-08-2016, 12:36 AM
mpuzach
mpuzach's Avatar
Received 1,190 Likes on 594 Posts
I find it both interesting and amusing that some owners think they know more than the engineers who designed the car.
Old 09-07-2016, 09:26 PM
Steve_R
Support Corvetteforum!
Steve_R's Avatar
Received 3,288 Likes on 1,399 Posts
St. Jude Donor '12-'13-'14-'15-'16-'17
Change it when the OLM tells you to. I do it when mine gets below 10%.
B&BVettes (09-08-2016)
Silver Stingray
Silver Stingray's Avatar
Follow the computers recommendations. They are in there for a reason.
dyesjamp (02-19-2020)
Old 09-07-2016, 09:29 PM
mpuzach
mpuzach's Avatar
Bingo.
Old 09-07-2016, 11:10 PM
dmvette
dmvette's Avatar
Good advice.
Old 09-07-2016, 11:12 PM
owc6
owc6's Avatar
Received 4,185 Likes on 2,679 Posts
All of the above is correct.
Old 09-07-2016, 11:14 PM
robertbruce
robertbruce's Avatar
Received 3,221 Likes on 1,580 Posts
3000 miles. I don't care what the owners manual says. I have changed oil at 3000 miles in every vehicle I have ever owned.
Old 09-08-2016, 12:36 AM
mpuzach
mpuzach's Avatar
The following 10 users liked this post by mpuzach:
Biker 911 (02-20-2020), Boiler_81 (09-08-2016), dvilin (09-08-2016), dyesjamp (02-19-2020), pittperson (09-08-2016), Steve_R (09-08-2016), VictorBarron (09-08-2016), woodsguy (09-08-2016), Woodson (09-08-2016), Z06NJ (09-08-2016) and 5 others liked this post. (Show less...)
Old 09-08-2016, 07:40 AM
JerriVette
JerriVette's Avatar
Received 3,946 Likes on 2,176 Posts
Today's oils..follow the Ow ears manual.
Old 09-08-2016, 07:57 AM
felkebg
felkebg's Avatar
Synthetic breaks the arbitrary 3000 mile rule anyway
Old 09-08-2016, 08:09 AM
Woodson
Woodson's Avatar
Received 1,356 Likes on 784 Posts
My OLM says about every 4500 miles.
Old 09-08-2016, 08:33 AM
2K14C7
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
And the oil companies thank you sir.
Old 09-08-2016, 08:39 AM
gregkoz
5th Gear
gregkoz's Avatar
I just found it confusing that the owners manual stresses the 500 mile oil change but after that it says in the book 7500 miles. however, the "fine print" states that Z51 and Z06 follow the OLM suggestions.
Old 09-08-2016, 05:00 PM
mpuzach
mpuzach's Avatar
An oil change after the first 500 miles is required on all dry sump C7s (Z51, Grand Sport, and Z06). There's a reason for it but quite honestly I'm not able to explain it intellegently. After that oil change, the "Oil Remaining Life" indicator should be reset and then used to determine when subsequent oil changes should take place.
Old 09-08-2016, 05:13 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
If you change the oil right now and reset the DIC, store the car for 11 months and 29 days, when you get in and start the car you will have 0% left (or close to it).
Time, rpms, temperature, miles, tons of stuff are in the DIC's decision to say "Change oil". Follow the DIC!
I'm not usually at 7500 for a 12 month time frame so I usually change oil once a year but I'd do it sooner if the DIC got below 10%.
Elmer
Old 09-08-2016, 05:16 PM
eboggs_jkvl
Has to do with the oil breaking down in the "Foaming" ability due to interaction with the gasket material used to seal the engine. After 500 miles, the interaction has ended and an oil change flushes the crap out and then the oil stays healthy and doesn't foam and get into the intake system.
Elmer
The following 2 users liked this post by eboggs_jkvl:
mpuzach (09-08-2016), Woodson (09-08-2016)
Old 09-08-2016, 05:52 PM
Zerski
Zerski's Avatar
youre just wasting money
To How often to change the oil in a C7 "Z", mostly city driving?
Old 09-08-2016, 08:12 PM
Nice Ride
Nice Ride's Avatar
There is no argument that motor oil has improved greatly from back in the day with use of blends and full synthetics over dino. Todays engines demand high quality oil due to higher operating temps. OK we get that. I think following the oil life monitor makes sense and after all that is what chevy recommends. That said FWIW I change oil and filter once a year whether the oil life monitor recommends that change interval or not. I paid 60+K for my Corvette and after a year in the car the oil has had a work out. The cost of fresh oil is not a big deal for the protection it provides and the piece of mind that comes with it. I also use top tier gas, carry increased ins. coverage and get an annual physical whether someone else thinks it's needed or not.
Old 09-08-2016, 09:16 PM
owc6
owc6's Avatar
Nice Ride, your car will say 0% at one year, even if you drive 0 miles. This is new from the C6 which didn't take calendar time into consideration.
lisa
Old 09-08-2016, 09:41 PM
GOLD72
GOLD72's Avatar
Received 1,101 Likes on 715 Posts
lisa
Quick Reply: How often to change the oil in a C7 "Z", mostly city driving?
