Ranger Method M7
Old 09-08-2016, 09:55 PM
kaplana08
kaplana08's Avatar
Default Ranger Method M7
Now that GM blacked out the C7 clutch fluid reservoir has any used the ranger method to periodically change out the fluid. I don't see a fill line anywhere inside the bowl like my C6 had. Please advise if anything has changed regarding the method. I guess it's going to be a bit of a pain to see inside when filling and when trying to see how black the fluid has become.
Old 09-08-2016, 10:07 PM
pickleseimer
pickleseimer's Avatar
St. Jude Donor '12-'13-'14-'15-'16-'17-'18-'19-'20-'21-'22-'23
Dip the end of a clean screwdriver into the fluid to pick up a drop and then deposit that on a clean white paper towel. That should give you an idea of how dirty the fluid is.
Old 09-08-2016, 10:38 PM
bearphoto
bearphoto's Avatar
SoCal Events Coordinator
St. Jude Donor '12
OMG, they are still using that same poor design that allows clutch dust to enter the clutch fluid?
After having 7 C5/C6 corvettes, all with a manual trans when I decided i wanted a C7 I swore I would not buy another manual trans corvette that had that same poor design. So I bought an A6 and it has been perfect. Although I prefer a manual trans I won't buy one that has that design. Thank goodness I did not go with the A8 which apparently continues to have issues (as reported on this forum).
Old 09-08-2016, 11:28 PM
A471133
A471133's Avatar
Yup. Use it every 6 months. The container is small enough to read where the line is when you put new fluid in. Its less than $5 for a container of DOT4 and I usually have to ranger method the whole container before it comes back clear. Workout for my left calf lol.
JerryU (09-09-2016)
Old 09-09-2016, 07:52 AM
RUSTYNKL
RUSTYNKL's Avatar
looked at my clutch M/C at 6 mos., fluid was black! Bought a turkey baster and DOT 4 fluid. I just change my fluid in the M/C every month, After 6 mos. the fluid is the color of light tea. Vette has 11,000 miles.
Old 09-09-2016, 07:56 AM
beepster
beepster's Avatar
Exact reason I bought the '14 rather than a new '15 at the time. I saw no reason to have an 8 speed auto in a vehicle that already achieved 30mpg...
Old 09-09-2016, 08:12 AM
JerryU
E-Ray, 3LZ, ZER, LIFT
Support Corvetteforum!
JerryU's Avatar
Received 9,598 Likes on 6,612 Posts
I do the same every oil change, which for me is usually once a year per the GM oil life indicator.
Since I do not track or drag race feel it is almost as good as the GM recommended proceedure every 2 or 3 years (my 2014 Owner's Manual says every 2 years the 2016/2017 Manual says every 3.) The GM procedure requires removing and exhaust pipe, catalytic converter, etc to get at the bleed valve! Have used the Ranger Method for my C6 for 5 years and the C7 now for 3 and no problems.
GM notes that some of the dark color is due to staining from seals so it does not reflect only contaminated fluid.
Also agree a good leg exercise! Not as much burn as 3 sets of 10 reps on my leg press machine but the ~210 pumps (30 pumps on 7 changes) does feel like I've done some good!
Old 09-09-2016, 08:48 AM
juanvaldez
juanvaldez's Avatar
There is a fill line if you look closely. I have a '16 Z51 M7 that now has 13,000 miles. I do it once a month or so. The first time when the car only had a couple of thousand miles lots of floaties came out. Now it just get a tiny bit darker. I only do a two or three changes with 30 reps between.
Old 09-09-2016, 12:41 PM
C7s
C7s's Avatar
Any particular brand of fluid you guys using?
Old 09-09-2016, 01:13 PM
08G8V8
08G8V8's Avatar
I'm sure you can use any DOT4 fluid, but the manual states "Super DOT4". I see Pentosin is one of the only fluids that is "super", and I saw on another forum that the GM fluid is re-branded Pentosin Super DOT4 so I am getting this from Amazon. The good thing is they sell a 1/4L bottle which is perfect for doing the Ranger Method and not having a bunch left over to sit on a shelf open until the next flush. A little more expensive than other fluids, but cheaper than GM branded fluid, and a more convenient size for this application.
The following 2 users liked this post by 08G8V8:
C7s (09-09-2016), driver9 (09-11-2016)
Old 09-09-2016, 01:25 PM
C7s
C7s's Avatar
Thanks! Just ordered some!
08G8V8 (09-09-2016)
Old 09-09-2016, 01:48 PM
BJ67
BJ67's Avatar
Shine a good light into the open reservoir and you can see down to the bottom if the fluid is clean, and or detect black or golden color. there are two lines on the outside of the Reservoir, minimum and maximum levels
Old 09-09-2016, 05:00 PM
TNSQUIRE
TNSQUIRE's Avatar
I changed mine out today with the ranger method. It took about 30 minutes and four cycles of changing the fluid and pumping the clutch 50x each cycle to get back to clean fluid. My car has 23,000 miles. The fluid was dirty but not dark black.
Old 09-09-2016, 06:14 PM
Foosh
Foosh's Avatar
Received 16,667 Likes on 8,311 Posts
Can someone please publish the complete "Ranger method?" I remember doing it on my '06 Z06, but I'm a little fuzzy on the details.
Old 09-09-2016, 06:27 PM
juanvaldez
juanvaldez's Avatar
Suck out the fluid, fill with fresh fluid, pump clutch pedal 30 times, repeat.
I do mine on a regular basis on a daily driver (13k in 11 months). Did two cycles today and fluid looked pretty good. I not a fanatic, use Valvoline Dot 4 for Advanced Auto.
Foosh (09-09-2016)
Old 09-09-2016, 06:34 PM
Foosh
Foosh's Avatar
Thanks, I also found Ranger's detailed write-up, attached below:
http://www.rangeracceleration.com/Clutch_Care.html
Old 09-09-2016, 07:26 PM
AORoads
AORoads's Avatar
Received 2,477 Likes on 1,940 Posts
St. Jude Donor '15
"In honor of jpee"
https://www.corvetteforum.com/forums...e-dot-4-a.html
Altho many, if not most, used Prestone DOT 4 easily available at stores like Walmart, it's obvious from the above thread that Super DOT 4 usually has/can have a higher wet and dry boiling point. See posts 9, 10, 14, etc. JoeC5 has pushed his C6 pretty hard and had no adverse effects from Prestone DOT 4, as well as many others who've used it. Doesn't mean the GM spec is wrong or off, just a possible alternative to use.
To Ranger Method M7
Old 09-09-2016, 08:08 PM
JoesC5
JoesC5's Avatar
Received 1,699 Likes on 1,213 Posts
Do not use a turkey baster as the plastic might not be compatible with the brake fluid and can crumble, dumping brake fluid all over everything.
Use the MixMaster that can be found in the two cycle aisle/section at Walmart automotive dept. It is made to be used with petroleum products.
The following 3 users liked this post by JoesC5:
driver9 (09-11-2016), pdiddy972 (12-20-2016), Z0HS1CK (02-26-2017)
Old 09-10-2016, 12:36 AM
driver9
driver9's Avatar
Thank you for that info, but some might find it helpful to know it's not MixMaster, it's MixMizer. Much easier to find online under MixMizer.
Old 09-10-2016, 11:35 AM
kaplana08
kaplana08's Avatar
Super dot 4 no longer available. now it"s GM brake and clutch fluid dot 4 comes in bigger bottle with little handle
http://www.parts123.com/corvettecent...50e&ukey=46412
Quick Reply: Ranger Method M7
