2017 GS front turn signal failure
I had the same thing happen to my 2016 with 2k miles on it last month.
The right front turn signal would go out intermittently. When it did go out it also caused the DRL lights on both sides to go out.
I took it in to my dealer (Kerbeck) for diagnosis and repair. They said it was a faulty ballast and replaced the whole headlight assembly under warranty
It works fine now.
The only downside is the front nose facia had to come off the car for headlamp unit removal and I was concerned because I had Xpel Ultimate on the whole car (including headlamps) and was worried about damage to the Xpel during the front end removal.
Kerbeck did a great job and the only problem I had afterward was having Xpel put on the new headlamp assembly when I got the car back.
It works fine now.
Have you had the 500 mile change done yet? If not you could combine services.
My luck, it was working at that time so they didnt do anything saying its not happening now so we cant do anything.
Wow, should not happen on a 2017 but stuff happens. I would go about normal routine and when the light decides to act up drive the car to the dealer when/if opportunity presents itself so the dealer can see and document the problem. I do not try to fix anything on the Corvette as long as it is under warranty.
After 5 hours they determined they have to replace the whole headlight unit. They will have to do it Tuesday when they get the part in since the parts people are closed on weekends.
Really sucks to see a car that isn't even a month old have go through a major repair (major because they have to take the whole front end off).
This car car was part of a lemon replacement. I can't keep dealing with problems, or else GM just needs to give me my money back.
Received 1,308 Likes
C3 of Year Finalist (stock) 2019
C2 of Year Finalist (stock) 2019
It sucks that you've have to deal with this, but hopefully it'll be the last bite you take of the chit sandwich. I for one appreciate that you followed-up on the forum with the outcome. Thanks for that, and good luck with the car.
They replaced my headlights today. Sadly when inspecting the car, I found this on the bumper (it has a little paint chip, might be able to tell in the pic). Really upset, but the service team said they can get it touched up, but that involves the body shop taking the bumper off which I do not want them doing. Idk what else I can get for this, hopefully I get can get my corsas installed for free.
Is the area shown in your photo between the front fender and the front bumper facia?
If so, that gap seems way to large. Is it the same on the other side? looks like the panel alignment is way off.
They had to remove the front facia to change out the headlight and it was probably scratched during the removal or reinstallation process.
The body shop most likely has more experience in removal and installation of body panels then the shop techs and if the shop is decent it should be an easy repair.
Good luck.
Good luck.
#33
Wow, a year later and I found the problem with my 2016 Stingray. Just checked prices and retail is $1375 and $891 from GM Parts Direct. Huge difference in price. Glad this should be covered under warranty.
