Stage 3 lip winglets
Hi,
Does anybody have pics of a non Z06/GS with a stage 3 lip and winglets? I can't find any good pics anywhere. I want to see if it looks weird without the Z06 side spats and wider stance. Really on the fence between stage 2 and stage 3.
thank you.
thank you.
https://www.ebay.com/itm/301964387718
What's your honest opinion on this?
It a lot cheaper than everything else. I don't care that it is just bare plastic and not painted.
https://www.ebay.com/itm/301995993914
The only thing is the lip doesn't come with pre drilled holes and I'm trying to think of a way to get everything lined up to drill holes?
I'm comfortable drilling holes in the lip, I'm stuck on how to get the lip lined up with screws under the front bumper cover, so I can drill the lip in the correct places.
You could use a bunch of c-clamps. HD has some of the light grip, quick release variety that simply hold parts together. It'll be frustrating but doable.
I too bought the expensive carbon versions from GM. Great quality and extremely strong.
Light touch with a center punch should allow you to drill without wandering all over the place with your drill bit. Also, do not use a regular drill bit. Bits for drilling plastic are tapered. You can get them at stores like TAP plastics. I've never looked for them anyplace else. I would imagine that they are available at other places hardware stores.
Received 1,762 Likes
