Front bumper removal video ?
Old 10-20-2016, 10:36 AM
Blck_c7
Blck_c7's Avatar
Default Front bumper removal video ?
I found one on YouTube but wondering is there another one ?
Old 10-20-2016, 12:42 PM
only9balls
only9balls's Avatar
I used this one (probably the same one)... I found it to be pretty comprehensive, the only tricky part he doesn't cover is removing the section between the hood and the headlights. You have to give it a good yank to get it out of there.
Old 10-20-2016, 12:44 PM
Blck_c7
Blck_c7's Avatar
Ok wish me luck .... trying it myself now
Old 10-20-2016, 12:54 PM
only9balls
only9balls's Avatar
It's not too bad, just take your time, he covers all the fasteners you need to remove in that video, make sure you get them all. I almost forgot the ones up inside, once you remove the bottom cover (he talks about them in step #4 at 1:20 in the video).
Once everything is unbolted, pull the bottom out a little first to disengage it from the car, then get your fingers underneath the top section between the headlight and hood (where it meets the fender), and pull straight up quickly with a good yank, it feels like it won't come out, but it will. There are two tabs that pop out in that spot, once those are out, the whole thing will want to fall off the car. Don't forget to disconnect the camera wires, if you have them, before pulling it all the way off.
Old 10-20-2016, 01:01 PM
Blck_c7
Blck_c7's Avatar
Now I got the brake duct that came with the grill but I c7 don't have it so it what hates to get to once the bumper is on ?
Old 10-20-2016, 01:02 PM
Blck_c7
Blck_c7's Avatar
I am trying to do this with no jacks or ramps .... should I just some ramp ?
Old 10-20-2016, 01:13 PM
only9balls
only9balls's Avatar
I have a Z51, which already had brake ducts, so I have never removed or installed those.
Old 10-20-2016, 01:14 PM
only9balls
only9balls's Avatar
It is easier to get to the bolts under the bottom cover if it is off the ground a bit, but it can be done without if no other choice.
Old 10-20-2016, 02:13 PM
Blck_c7
Blck_c7's Avatar
Got the centre piece out but I had this plastic deflector.... do I need to remove the sides also
Old 10-20-2016, 02:51 PM
only9balls
only9balls's Avatar
You should only need to pull the bolts that are mentioned in that video... your picture is blurry, so I am not sure what that is
Old 10-20-2016, 03:37 PM
Blck_c7
Blck_c7's Avatar
What's the best way to yank the bumper off ?? Feel like it's going to break if I keep it up
Old 10-20-2016, 03:46 PM
Blck_c7
Blck_c7's Avatar
Feels good working on my own car
only9balls (10-20-2016)
Old 10-20-2016, 04:05 PM
eboggs_jkvl
Moderator/Tech Contributor
eboggs_jkvl's Avatar
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes on 2,058 Posts
2015 C7 of the Year Finalist
Use an upholstery removal tool to pry up under the bumper cover. Start the tool at the headlamp pod side go in about 2 inches and pry up. The cover will pop off without yanking up on it and risking destruction of the TAB on the bumper cover.
Elmer
Old 10-20-2016, 05:35 PM
only9balls
only9balls's Avatar
When you put it back on, pay very close attention to the two tabs that slide in under the headlight on each side, they are easy get folded over and not slide in correctly.
To Front bumper removal video ?
Quick Reply: Front bumper removal video ?
