Rear reflectors
Rear reflectors
How does one remove the rear reflectors that are below the tail lights ( the thin, horizontal ones)? Thinking about adding LEDs to make them running/tail lights.
Received 1,984 Likes
They snap out, use a plastic tool to gently pop out. There are videos on here if you search about removing the rear fascia, not the rear bumper, don't get the wrong video. Pulling off the reflectors is the first step as there are screws behind the reflectors to hold the rear end on. Removing the fascia is necessary to change out the exhaust so numerous how to's around.
https://www.corvetteforum.com/forums...ar-fascia.html
