Warm up
Old Dec 15, 2016 | 01:31 PM
BJ67's Avatar
BJ67
Originally Posted by Kracka
Fire it up, buckle your seatbelt, and head out. Drive gentle until it gets heat in it then have fun.
Sitting and idling warms only the engine, your transmission and differential fluids will still be cold.
Manual transmissions spin during warm up and transmission fluid circulates in auto transmissions during warm up.
Old Dec 15, 2016 | 01:34 PM
Kent1999's Avatar
Kent1999
Originally Posted by Armyav8tor
My cars sit at idle in the morning for about 15 secs, enough time to put my seatbelt on and get the Bluetooth working.
10-15 seconds idling so all the fluids get circulating, and then drive off, going very easy until I see the oil temp hit at least 100 deg.
Old Dec 15, 2016 | 01:41 PM
Kenny94945's Avatar
Kenny94945
Here's my opinion.
Start car wait for oil to circulate throughout the engine...maybe 30 seconds.
Drive off, use low rpm, until engine is at operating temperature.
Then note your tires may still be "cold" and with street traffic may take 10 miles to warm.
I have no comment about warming the trans and diff oil as I make the assumption once tires are warm so are all the mechanical.
So there you go an opinion.
Old Dec 15, 2016 | 01:43 PM
pickleseimer's Avatar
pickleseimer
St. Jude Donor '12 thru '24
Start, adjust seat if necessary, buckle up, check mirrors, then drive off. I keep the engine under 2500 rpm until oil temp reaches 160. If cold out I wait a little longer until the shifts are no longer stiff on the manual cars.
Old Dec 15, 2016 | 01:44 PM
Bill Dearborn's Avatar
Bill Dearborn
Originally Posted by yeller z06
I disagree. All modern cars are designed to start it up and move it out. As long as you take it easy, you won't hurt anything and it actually warms up faster, which is better for the engine and transmission both.
Having it sit and idle until warm does nothing for the tranny, differential, etc.
The correct answer. Get in, start car, fasten seat belt, check your heater/defroster settings, check your mirrors and drive off easily. The time it takes to fasten your seat belt and do these other safety related things is sufficient to get the oil flowing through the engine. The engine warms up much faster and is actually abused less than letting it sit and idle until the temp comes up to 100 degrees.
It has nothing to do with the environment.
Now if the car is covered with a foot of snow you clear a path to open the door so a boat load of snow doesn't fall into the car, start the engine, get your snow brush, clean the rest of the car and then fasten belt and drive off.
Of course this only happens when it is 10 degrees or less, your gloves fell out of your coat pocket, you don't have the proper shoes or coat on and the wind is blowing at 20 mph resulting in you freezing your butt off. Then you have the fun ride home.
Bill
Old Dec 15, 2016 | 01:46 PM
Zaphod B's Avatar
Zaphod B
I just wish there were a way to warm up the M7 before driving off - mine is balky as hell going into 2nd until it gets well warmed on a cold day.
Old Dec 15, 2016 | 06:35 PM
Larry/car's Avatar
Larry/car
My wife takes care of the warm up. Always a minute or two wait after getting the car out of the garage.
Old Dec 16, 2016 | 07:24 AM
yeller z06's Avatar
yeller z06
Old Dec 16, 2016 | 07:34 AM
hangman's Avatar
hangman
That's what burnouts are for
Old Dec 16, 2016 | 07:45 AM
Black 03 Z06's Avatar
Black 03 Z06
If engines require no warm up why do the engineers at the various car manufacturers put block heaters in their vehicles?
Old Dec 16, 2016 | 08:06 AM
pbergmann's Avatar
pbergmann
This thread is a great testament on why used late model Corvette's are such great second hand cars.
Owners for the most part take better care of the cars than they do of their own health.
Old Dec 16, 2016 | 09:50 AM
Boiler_81's Avatar
Boiler_81
As others have said, start it and drive it. The dry sump engines will take a bit longer to come up to temperature due to the greater volume of oil. So it will take a bit longer for the yellow to disappear from the tachometer.
Originally Posted by woodsguy
I thought I saw a thread on this but can't find now. But a discussion was started on Facebook in the BMW owners thread(bikes) about no warmup, crank and ride off.
I thought I saw on the dry sump engines they need to warm up??
Old Dec 16, 2016 | 10:14 AM
  #33
ersatz928's Avatar
ersatz928
People blindly follow "Start it and drive it right away" as blindly as I follow "Start it and let it warm-up for about 3 minutes before you drive it".................
Old Dec 16, 2016 | 11:33 AM
  #34
Boiler_81's Avatar
Boiler_81
Old Dec 16, 2016 | 11:42 AM
  #35
joemessman's Avatar
joemessman
Originally Posted by Boiler_81
Thanks for posting that video. I am quite eager to see what is posted in response to the video.
Old Dec 16, 2016 | 12:29 PM
  #36
millpond's Avatar
millpond
Great video. I just wait until the idle speed stabilizes, then drive lightly until the engine is up to full temp.
Old Dec 16, 2016 | 12:34 PM
  #37
BJ67's Avatar
BJ67
Change the trans fluid to a full synthetic like Amsoil Torque Drive and that 1-2 shift will be a lot better.
To Warm up
Old Dec 16, 2016 | 12:39 PM
  #38
themonk's Avatar
themonk
From: Calgary, AB. There's a reason why white was the only color offered on every year Corvette. Proud Canadian German Jamaican!
St. Jude Donor '09, '12-'13-'14-'15-'16-'17
on a cold start (overnight) I wait 30 seconds, by the time I put on my seatbelt, get comfortable, play with the stereo, I'm good to go.
If it's already been warmed up, I just wait about 10.
Old Dec 16, 2016 | 12:47 PM
  #39
Woodson's Avatar
Woodson
Double-clutch the 1-2 shift until it's warmed up.
Old Dec 16, 2016 | 12:56 PM
  #40
Greg00Coupe's Avatar
Greg00Coupe
Sometimes common sense is your best source. Starting her up and idling for say 30 seconds and gently moving out is probably best. Hammering a cold car is a short term thrill when the premature wear catches up. Works for cars and women.
Watch your oil temperature gauge and see how much longer it takes for the oil to come up in cold weather. Takes a long time to get 10 gts of oil up to temp.
