Do I need a Catch Can? 2017 Dry Sump
Former Vendor
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'11-'12-'13
Not that I have seen. The only stock car I have seen with a catch can is the new Camaro's and it is more of a separator than a can.
By law (emissions) they can't really put a can on the cars as they have to process all of the oil vapors and burn with the cats. Yes it is a good idea to do if you want to keep oil out of the intake system.
From Ask Tadge: "The Corvette's dry sump tank looks relatively simple on the outside but the internals are really quite complex. The top third of the tank contains a PCV air/oil separation system"
https://www.corvetteforum.com/forums...te-engine.html
BOBSZ06 (01-01-2017)
JerryU (12-29-2016)
E-Ray, 3LZ, ZER, LIFT
Received 9,608 Likes
That crackcase oil vapor and other "stuff" goes thought the PCV hose to the intake. A "catch can" catches some of that stuff! What percentage is caught-I don't know. I remove some "stuff" periodically from my "catch can." Better removed than going into the intake, IMO. Before DI, gasoline with cleaning additives washed the oil residue away. With DI no gasoline passes the backs of the hot intake valves so it bakes on!
GM or the EPA could never allow a "catch can" to be installed as it must be emptied periodically. Many folks don't even check oil level when they should! What would they do with the collected oil? (I change my own oil so put that collected in my catch can into that 15 gallon container and dump in our local SC waist disposal location when I change oil. Would everyone?)
If the oil and "stuff" is not removed from the can, Tadge was correct, it could cause a problem. For those who want to use that excuse to avoid adding one-sobeit! I elected to add one and glad I did.
Muzzy (01-04-2017)
FL Events Coordinator
Rather than get into a long debate about whether it is good or not to have one....Let me say this. If you intend to make this C7 your LAST Corvette, by all means I think the "catch can" is the way to go....but most of us trade every 4 - 5- 6 years with no more than 30 - 40 thousand miles if that. In that case, installing a catch can is not warranted. IMHO As a added note....this debate has gone on since the C5. I traded my 02 for my 08 with 22,000 miles....my 08 with 31,000.
The following 3 users liked this post by obxchartercaptain:
I installed a ported intake at 8,000 miles. Amount of coking was alarming for that few miles. However, my dealer overfilled by a quart at my first oil change even after I instructed them to only put in 9 quarts, and of course they put in 10 quarts so I am sure I ran a good 1/2 quart right through the intake. I think a catch can is prudent if you are going to keep the car a few years:
Like folks who get all concerned about finger prints on their door and hatch and devise ways to avoid it (some carry a microfiber rag in their pocket, some use their shirt, some only close the door by the chrome latch etc)- I could care less about finger prints BUT do think about the caked on carbon building on my valves! Look up other high performance engines that started using DI before the C7. In fact some of their engines have even multiple smaller intake valves that may not get as hot as the large C7 vales, etc. Ferrari, Porsche BMW are concerned. No simple solution and GM engineering is great but they can't change the laws of physics! A catch can can help.
Your car, your choice but can't justify it as "it's not needed, IMO!"
This is an old Shell ad, again only effective with port injection or a carb, i.e. C6 and prior Vettes! Can't do a thing for a C7 DI engine as ZERO gas passes over the intake valves!
Muzzy (01-04-2017)
Hmm, 1st a C5 (and my C6) had port injection and gasoline with cleaning additives washed the oil from the PCV system from the back of the vales before in baked on!
Like folks who get all concerned about finger prints on their door and hatch ans devie ways to avoid it (some carry a microfiber rag in their pocket, some use their shrt etc- I could care less about finger prints BUT do think about the "stuff" building on my valves! Look up other high performance engines that stated using DI before the C&. In fact most have even smaller valves that may not get as hot etc. Ferrari and Porsche are concerned. No simple solution and GM engineering is great but they can't change the laws of physics!
Your car your choice but can't justify it as it's not needed!
This is an old Shell ad, again only effective with port injection or a carb! Can't do a thing for a DI engine as ZERO gas passes over the intake valves!
Steve_R (12-30-2016)
Received 8,919 Likes
My Z uses so little oil it isn't noticeable on the dip stick. Even the GM Recommended half quart overfill for track duty doesn't noticeably drop over two days of high rpm fun. My C5s and C6Z would use about a quart a day while at the track. Over the year I have had the 15 Z I have only had to top off the oil once. This may be my last Vette but at 5K miles per year any oil coking problems won't show up for another 15 years.
Bill
Dcasole (04-15-2020)
If you go to the C5 & C6 forums and do a search you will find many many many threads on "Catch Cans" I am not debating the fact that the DI engine is different ... but PCV has been around a LONG time. And, in my opinion if you trade your car every 4 to 8 years with less than 50, 60,000 or more miles....A Catch Can doesn't do a thing for you.
obxchartercaptain (12-30-2016)
Hmm, 1st a C5 (and my C6) had port injection and gasoline with cleaning additives washed the oil ingested from the PCV system from the back of the valves before it baked on!
Even Consumer Reports in their 2015 report on DI and its advantages/disadvantages stated that not all DI engines are affected by valve coking.
Bill
There is also the warranty consideration. GM has denied warranty for engine failure due to catch cans. If you do have one, I would think it would be in your best interest to remove it prior to going in for GM service work.
No way am I going to take a risk on installing a catch-can on my LT1. It does seem to make people feel better to find a little oil in it once they've installed one, but I haven't seen any compelling evidence that it's useful on this engine. There is a fair amount of credible info suggesting that they are not necessary or useful on an LT1 dry sump engine.
I think Bill Dearborn said it best above.
Well if true this is the real answer for not having one.
