Winter driving - what's the risk?
The salt will turn you aluminum dull if not rinsed.My c5 aged quickly from a previous owner.Guess depends how CLEAN underneath you want it? Or the next owner? If resale is a thought?
The C7 Has a ton of electronics.Being from the same republic as you.We know what that NASTY CRAP is capable of.
After roads are plowed and dry.Notice the amount of that crap sitting in the center of the road and sides.The surface is white.It's a powder.They are putting that crap on heavy lately!!
Powder goes and collects in areas.Then add condensation and melting and spray and electrical connection's and electronic sensors
If your keeping it? Nope..Park IT and look at it.Or move
MY OPINION..Your Car
To answer your question directly - the corrosive salt on the ground will make any ferrous metal fasteners on your vehicle corrode. The overall appearance of the undercarriage will degrade - stuff that looked shiny will eventually look dull. Lastly, the salt and sand greatly enhance the likelihood of chips in your paint and windshield. On the C6 it was easy to tell if a car had been driven in crap - the edges of the fenders directly behind the wheels would take on a sandblasted appearance. The C7 has black plastic there so the damage would be better hidden. It's certainly possible to drive - but you'll take the "glow" out of the car, especially underneath and in the wheelwells. Only you can decide how important that is to you. I will continue to drive the Mercedes SUV now and let the Vette sleep...........
Not immune but the reason we acquired the SUV is to use it as a DD. We turn that vehicle "line" every 30K-40K which is about every 3 years.
It's unfortunate you aren't financially stable enough to be able to afford to have a second vehicle to drive in bad weather.
Yeah - I can play that game too.
joeybsyc (12-29-2016)
Received 19,284 Likes
'20-'21-'22-'23-'24
I live upstate NY and we can get some serious snow and very cold weather. I see -30F at times! My DD is a 4x4 PU for a very good reason. My wife drives a SUV as a DD also! As I type this it is snowing and the weather guy said it will be over a foot!
Its not only the snow its the heavy amount of sand the DPW uses. That stuff is like being sand blasted and it will stay on the road for weeks/months after a snow fall or ice event.. Its also VERY slippery. Of course we get serious amounts of salt and some other chemicals they spray on the roads!
Even if your the worlds best driver there are plenty of kamikazes around to run into you or put you in trouble.
This is my 7 Vette and only once with my first Vette did I drive it in winter. (believe it was the winter of 87)
Hey its your car do with it want you want, I prefer mine to sit under a cover in the garage under my house for the bad weather
Received 8,926 Likes
Having Vettes for over 12 years and living in New England, I have always stored my car for the months of December thru March.
Over the Christmas holiday, I was passed by a Corvette Enthusiast who was out enjoying his car.
Thought to myself, you are really missing some great driving.
Yes I know that typically Classis Cars are taken off the road because the steet metal and frames would be eaten up by the salt on the road.
So if the roads are not icy, even though there could be salt on the roads, and I have invested in a set if All Season tires, what is the risk of driving our Vettes in nice weather during the winter?
Also, I knew that my Goodyears would lose grip around 50 degrees, but what are the temp limits of the current Michelins.
Not trying to beat a dead horse or start a controversy, but would be interested in the Forum's opinions.
The best way to store the car is to drive it since the car was not designed to sit around and sitting around for extended periods of time is an abuse of the car. Abuse, because it is doing something with the car that it wasn't designed to do.
I bet you have at least two days per month during the winter where the roads are dry and you could drive the car. One thing I found about driving the car then is it is more rewarding than in the summer. Think of it. You don't get out of work until it is just about dark, you have cabin fever big time and then you hop into the Vette, hit the starter and that snappy roar brings a flow of endorphins into your blood stream and you take the car for a 40 mile joy ride. When you get back you have a smile on your face and feel good for the next week. Why wouldn't you do that.
As for potential salt making your aluminum dull it really doesn't matter because aluminum is supposed to do that. That dull look is a layer of oxidation (corrosion) that protects the metal underneath it. Iron doesn't react the same way.
From http://www.aluminiumdesign.net/desig...on-resistance/
Aluminium corrosion resistance is very good in untreated aluminium. Untreated aluminium has very good corrosion resistance in most environments. This is primarily because aluminium spontaneously forms a thin but effective oxide layer that prevents further oxidation.
Aluminium oxide is impermeable and, unlike the oxide layers on many other metals, it adheres strongly to the parent metal. If damaged mechanically, aluminium’s oxide layer repairs itself immediately.
This oxide layer is one of the main reasons for aluminium’s good corrosion properties. The layer is stable in the general pH range 4 – 9.
A plastic and aluminum vehicle seems to fit your thinking nicely.
Bill
Foosh (12-29-2016)
How is that different from all the drivers texting all year round? I've always found summer drivers far more dangerous. I don't understand why you're worried about a little salt, water, or an occasional icy patch on the roads either if you have proper tires.
Obviously, you must be driving something around in the winter, unless you have all you need for 4 months stored in the cellar. It's just a car like any other car, except in deep snow.
It's bad driving anytime of year the way people drive now.
Just don't enjoy driving the Vette in winter unless the roads are dry and clean and then just to give it a run.
I do have everything needed at home including my shop and the SUV in winter for errands, food etc.
The past 8 years I put 3 times more Summer miles on the corvette/s than my last 3 daily drivers.
Only put 3000 miles on the SUV since 2012 and just put 6500 on the C7 in 12 months
The Vette is for travel and enjoyment.
On the other hand, eventually moving to Florida full time
Foosh (12-29-2016)
I drove the car once while it was in the 30's and had little traction on the stock tires, which is my own fault since it was so cold. I did use my other vette once through a winter. It's absolutely horrible if you encounter snow. My car is in the garage now.
I would not buy this car if it had to be a daily driver considering I'm in a northern state.
A question to all those who are worried about a little salt turning the aluminum chassis dark--when is the last time you had a car appraised for trade-in that someone examined aesthetics of the underside of the car? Moreover, the difference on a trade-in price between a pristine-appearing car and a good condition car is usually maybe $1K at best. Mileage is the primary determinant of trade-in price.
If you want the best trade-in price, you do what a lot of Corvette owners do and leave it in the garage just to look at like a museum piece. Actually driving it is going to really ding your trade-in value because of mileage, but it's going down whether you drive it or not.
Even though the C7 can be driven in light snow and cold (providing use of All Season or Snow tires) I just as soon keep mine stored in the garage till Spring time. I enjoy this car most in the Spring, Summer and early Autumn months with the top down and the sun shining. Keeping the car stored for 4 or 5 months keeps it out of harms way, keeps the miles low and gives me something to look forward to in the Spring time. To each their own!
#33
Sonic,
You see that's the part I really don't understand. Driving it only in summer does not keep it out of "harms way." In my view, I think it much more in harm's way during summer driving. In winter weather, people tend to stay home and hibernate, thus there is far less exposure.
#34
Received 3,289 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
Bingo! It's depreciating whether you drive it or not. To each their own, but I buy cars - including Vettes - for ME to enjoy, not to keep them pristine for the next owner.
#36
Sonic,
#37
I don't think salt has any meaningful effect on the trade-in value of a Corvette.
#38
Us guys that drive our vettes year round are not trying to convince everyone to do it. If you like your SUV in the winter and storing your C7...more power to you.
The main point I try to make is its a very capable and fun car to drive past November with the right tires. I'm not too concerned if the bottom of the car looks weathered when I trade her in. Xpel keeps the outer parts looking brand new year after year.
#39
There are risks driving it or storing it. I met a guy at a cars and coffee that shut his garage door one day and the sheet rock from the ceiling crashed down and destroyed his car.
#40
I live in Nebraska and will be driving my C7 whenever the roads are dry and the weather permits. My C5 was a garage queen, but I will be driving my C7 whenever possible. Not going to winter my Vette. It depreciates regardless so why not drive it?
