DSC Sport Magnetic Shock controller observations
#1861
Mike,
When will the C7 controller become available?
Will the new controller work with the older C7 mag shocks?
I liked my V2 and V3 controllers, but wound up selling them. I am looking to get back to one, but they have been unavailable. I called back in August to order and found they where on backorder. Now we are in October and the status is still backorder. Any insight on when the controllers will be available for purchase?
#1862
For my car, the DSC controller does not set any ECM codes or flash any warnings on the instrument display.
However, the monthly Onstar report shows warnings about a communication problem on the CAN bus, so most systems in the report are yellow warning triangles.
With the factory controller, all systems are OK (green).
Does anyone else see this effect on the Onstar report using the DSC controller?
#1863
My own personal observation of DSC is that they make a very good product but totally lack in customer service and meeting their own commitments. I have been waiting for the PTM settings since I bought my controller and was told at the time "it will be ready in a couple of weeks" and that was many months ago. They haven't responded to my email inquires as to when it would be ready. I see others on here have the same issues. Suggestion to DSC; get promises filled, only deliver units that are customer ready, and give us real dates . I would love to see forum members boycott any further purchases until they just do what they say when they say it, I don't think that is too much to ask. I would have much rather been told when I made my purchase that while the unit will work, it lacks PTM and it won't be ready for ???, and then let me decide if I wanted to go ahead with my purchase.
#1864
I've never seen or heard of your OnStar symptoms being tied to a DSC controller. It didn't happen on my 14 or 18. Even though PTM doesn't work on my '18, I don't get any error codes on OnStar or anywhere else. It doesn't allow me to enter the PTM menu, but all the normal modes work perfectly.
I also agree that I'm beginning to lose patience w/ the promise to get the PTM problem fixed on 18 and later MYs. However, I've also had a half-dozen conversations with Mike about it, and he is trying. They just haven't yet isolated exactly what the problem is.
I delayed installing the DSC in my 18 until Mike thought he had it fixed in late spring/early summer. He called and asked me to bring it in so he could test it on my Z51. He was surprised and frustrated that the PTM fix didn't work. He is trying. I still much prefer the DSC normal modes to the OEM MSRC upgrades, but I do miss PTM.
ashmostro (10-19-2018)
#1865
Bump stops
Does anyone have any practical experience with the bump stops in the velocity tab? I would like to use them to avoid bottoming out the rear shocks when I have a passenger and stuff in the trunk.
I think I would need to be in the "Compression" part.
I assume the "Start" value would be where the shock starts slowing down its compression (say at 20 mm ?), the "Stop" value is where I want the shock to stop compressing completely (say at 25 mm ?). But what about the "Current"? Is that an indication of the slow down rate?
Does this make sense? Anyway played with this?
kensredvette2 (10-19-2018)
#1866
#1867
I am also moving toward the opinion that the DSC velocity tuning rather than the damper cal table is key to gaining the mix of smoother ride without 'float' or 'bottoming'. I will not be able to do testing for a while with the DSC, so I am looking forward to feedback from those that tinker with the velocity settings. Cranking up the damper current at the low end of the DSC cal table is kinda the 'old school' approach. MRC should be able to deal with boulevard conditions without being 'surprised' by a bump or dip.
Good luck and looking for some feedback. For the moment, I am running the GM MRC Update, which is not quite as good in steady state, but much better at transient conditions and doesn't raise errors with the monthly GM onstar diagnostics report.
#1868
#1870
Former Vendor
Let me know if this makes sense
#1871
Former Vendor
#1872
Former Vendor
#1873
Former Vendor
Regards
#1874
I am having a problem with the OnStar diagnostic report, but I didn't connect it with the DSC controller installation. The error message on the report is "We were unable to successfully complete a diagnostic test. This issue may be caused by an aftermarket device plugged into your vehicle's diagnostic port." Too much trouble to switch out the controller and put the OEM one back in to see if that's the reason. I don't have anything plugged into the OBD port.
#1875
"Hey Tim, controllers are in at HQ being bench tested for approval for shipment. You should be getting a shipping notification by the end of the week once the engineer has cleared thru the new inventory."
#1876
Tractive setup question
For those that upgraded to Tractive RT or RTx, can you provide some feedback vs. stock MR+DSC controller specifically on the track?
- I know the shocks have more range than MR, so does it mean it can go stiffer than MR can? I feel MR with DSC still have 2 much body roll, and too soft for smooth tracks like Laguna. My fronts compresses too much going down corkscrew and scrubs the fender well extension everytime!
- Did you get it with the Swift springs for a full coilover? Thanks!
#1877
Former Vendor
David
David
Regards Michael
#1878
David the tractive are amazing il try to post some dyno graphs to give everyone an idea of the range difference the only draw back to the MR other than heat is the dynamic range they really only control low speed range 0-2"/sec a full range mono tube shock or a race shock is 0-20"/sec the most critical is 0-2"/sec to control the initial hit of the tire and 2-6"/sec is critical to control the chassis and the high velocity wheel movements. you will find increase in entry speed as well as a better exit due to the full range of the shock you still have all the ride quality of the MR and you dont have the heat problems assoc. with the MR at high load. when you can download our tuning software and look at the velocity tables
Regards Michael
Regards Michael
#1879
Yes your on the right track bump stop is huge make sure to fill in all the values I want to post a bump stop map but it requires proper ride ht zeroing as it's dependant on static height . Build your tuning file and email it to me I'm glad to edit it or start a DSC bump stop thread then others are not confused . It's a powerful tool if used properly
#1880
Former Vendor
I believe I just sent you back the bump stop file I updated the velocity section to put down more grip on accel and filled in the bump tables write all I just flashed a board here works perfect you must reset ride ht verify with the data this is the critical part when using the bump stop or you could always be on the stop got it
