Any video on passenger trim pad removal replacement?
Does anyone know of or seen any video regarding how to remove C7 Z06 Passenger Trim Pad above the glove box with the two adjustable AC vents?
I found one to replace the instrument upper dash trim pad, which was just wonderful...but the Passenger Trim Pad seems more complicated.
I know Tadge has a written synopsis, but that video sure made it look easy!
TX,
NW
TX,
NW
Does anyone know of or seen any video regarding how to remove C7 Z06 Passenger Trim Pad above the glove box with the two adjustable AC vents? I found one to replace the instrument upper dash trim pad, which was just wonderful...but the Passenger Trim Pad seems more complicated. I know Tadge has a written synopsis, but that video sure made it look easy! TX, NW
I'm looking for a good 2 LT black dash pad w/grey stitching, if you happen to be swapping one out/getting rid of one...
Here are some instructions for the removal process:
https://www.corvetteforum.com/forums...nger-dash.html
Lake you have a PM.
NW
Removal link
I have read this over many times and printed it out and will use it as my guide....hopefully I can get to that screw on the far left from inside and get everything released....
Thanks,
NW
