Deluxe Alternator Cover for the C7 Corvette
C7 of Year Finalist (performance mods) 2019
DAAANG (07-08-2017)
It's an easy install, don't sweat removing the coolant bolts everything stays put with no leaks. I routed my lines in their original position, but the one plastic line clamp you have to remove on the alternator i just flipped it around so that the little grommet that stuck in the alternator housing now holds it under the cover on the back side...hope that makes sense.
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
for the
C7 Corvette
for the
C7 Corvette
Cover up the Ugly Alternator in your C7 Corvette with this Deluxe
Alternator Cover. Offered in a wide array of Inlay Color Options.
For More Information, Please follow the link Below
Tks
CCA
The only thing I found that was a bit tricky was the need for a right angle #30 Torx to make it easier to remove and tighten one bolt. Found a cheap set on Amazon, worked fine.
bankers1 (01-25-2018)
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
Chip, these look great! Do you have a photo of one with the black Carbon Fiber?
CORVETTE TODAY Host
St. Jude Donor'15
No worries, sir! I have a Halltech cold air intake. Will these fit with that in place so close to the alternator?
