contact DocZ@1stRateCorvette..........forum vendor here..........can get you OEM Black Cup Wheels, similar to those you have shown above................
Does the OP have a Stingray ? I was told by several sources that Cup wheels won't clear the Brembo brakes on the c7 Stingray or Z51 and that NOBODY is making replicas for the Stingray / z51 which is a disappointing for me.
It may be a 1st world problem but it still sucks...
Does the OP have a Stingray ? I was told by several sources that Cup wheels won't clear the Brembo brakes on the c7 and that NOBODY is making replicas for the Stingray which is a disappointing for me.
If you can find them for the C-7 please post. The Cup wheels were also used on the C6.
At this point, there are none that fit the Stingray or z51 due to the brake caliper clearance issues and , as I indicated, every wheel shop I talked to said that nobody is making CUP replicas that fit the C7 Stingray / Z51.
So, the outlook of getting Cup wheels on said car .... don't look to good.
The Z06 is a totally different story as Cup wheels do fit.
