Leak under the car
Leak under the car
I noticed drops of fluid in my garage towards rear of car driver side.
I think a seal is leaking 2015 c7 manual
11k any one else ?
11k any one else ?
Received 1,694 Likes
St. Jude Donor '15
What color was it?
Received 1,762 Likes
ttt
Need more info on the leak.
St. Jude Donor '15
That's a very confusing answer.
Woodson (02-26-2017)
DogTag-C7R (02-26-2017)
I officially nominate this for "worst thread of the week" in a way its just awesome though. We should start that thread - worst of the week - I remember the question - I am pressing the gas pedal and brake pedal at the same time, what do I do?
Last edited by Steve Garrett; 02-26-2017 at 09:32 PM. Reason: No need to re-quote the previous post, especially if you're the next person posting.
Followed closely by, "how do I remove my girlfriend's footprints from the passenger's side dash?"
Just looking to see if anyone else has a similar leak.
Thats why I posted I never had a vette just bought it for the looks always had *** cars. No problems. I guess no one want to admit there still not up to par look great sound great . Ok well
St. Jude Donor '15
No one understands your post. It's really not clear what you've described.
Mike every one in here wants to help you with what is going on with your cars leak. How about post a pic of it or give more info on it color what it may small like if anything at all. This is what we are looking for plus what may help also where under the car do you think it was coming from buddy.
OP,
If you want start a thread seeking help and advice on a car forum, you'd be smart to hang around for the discussion. Otherwise, don't bother.
There are a lot of very helpful and very knowledgeable people here, but getting good advice requires a good description of the symptoms. You haven't provided anything close to that, or even bothered to hang around for the people trying to help you.
Leak
OP,
When I place my hand on the axel or rear suspension
it is wet the other side is bone dry. I'm thing this is the burning smell.i have pictures and am going to upload.
[center]
I here that I joined the site a while ago but reall have not been on to much and now noticed drops of a clear fluid directly between the driver rear tire and where the axel goes in to. I'm not to familiar with what the actual parts are called. The burning I smell is very slight. I noticed it over the summer time. But just thought it was from driving hard. So I noticed this because I took the car out for a spin on Friday and saw some drops of fluid when entering my garage
If it's in the area where the driver's side, axle half-shaft enters the differential, the most likely suspect would be a leaking differential seal, but that fluid would be oily and not likely clear.
If it's wet on one side and not the other, take the car in to a dealer and have them take a look. This is certainly not an issue I've seen reported here.
Leak
OK, are the drops oily or more like water?
yes they
If it's in the area where the driver's side, axle half-shaft enters the differential, the most likely suspect would be a leaking differential, but that fluid would be oily and not likely clear.
yes they
