Brake rotors rusting
I have a 2015 Z51 and enter a lot of car shows. One of the things Im bug'd about is how the center of the rotors are rusted! It really takes away from the clean detail of the wheel assembly and barrel. I was told that the standard Stingray has a treatment on there rotors and explains why I have never seen this problem with the base model. So why would the base unit have a treatment and the Z51 option not?? Any solution short of having to replace the rotors.
The only ones I've ever seen w/ rusted rotors are cars that are washed and left to sit. I certainly don't see it on my Z51 which is driven 4-5 days a week. Use the brakes and the rust is gone.
Received 1,694 Likes
St. Jude Donor '15
I've seen people paint that hub.
Received 2,225 Likes
Check out:http://www.theglobeandmail.com/globe...ticle11408699/
So this is what the base rotors have that the Z51 rotors don't.
Ferritic Nitro-Carburized-treated rotors(a chemical case-hardening process whereby nitrogen and carbon are diffused into the surface of a ferrous metal such as steel or cast iron.) have a 400-micron (one-tenth the width of a human hair) layer of protection. Once this layer is worn through, the cast iron rotor can be treated like a normal one and machined if necessary.
Because the pads on the Z51 are more abrasive than the base pads, they would wear through the thin coating too quickly for it to be worth the cost of doing.
c7fasteddie (03-04-2017)
Yep, that's the price of stopping more quickly.
I lived with that problem on my 2009 Acura for six years. A year ago I painted them with "Majic Rust Kill", described on the can "as an oil-base aluminum rust-preventive coating, for metal substrates only." Before painting I cleaned them as well as I could with a wire brush and air jet. They still looked rusty, but the paint has held up perfectly in that time. It's not a big job if I have to redo it after a while. It came in a half-pint can ($4.59) and I probably have 80-90% of it left. It is a bright aluminum color, and I am happy with the look. (My Acura wheels are aluminum; for black wheels you would no doubt want black paint.) No need to remove rotors from car to do this job.
The entire "base" rotor is baked so the center gets the coating also. The Z51 has no coating.
Base rotors after washing.
Received 3,115 Likes
Finalist 2020 C7 of the Year -- Unmodified
Just clean them with a cleaner that will remove rust Good Luck!
Yes, they rust. Use some caliper paint on them. This is the G2 system applied. A bit pricey but seems to hold up good for me. Use a rust remover with a wire brush to get the rust off. Even some household CLR will do it if the wife has it around. You have to let it dry a while so be prepared to leave it up on jack stands overnight.
Foosh (03-04-2017)
Below is a related thread with regards to the rusty "hat." There's only a thin layer gray paint, which can wear off... and some wheel cleaners can removed the paint exposing the metal resulting in rust.
https://www.corvetteforum.com/forums...-included.html
Foosh (03-04-2017)
THANK YOU - I was getting exhausted just reading the prior comments. The newspapers are correct - reading and comprehension ARE leaving the US............
joeybsyc (03-04-2017)
I painted the center hub area, or hat, with rustoleum black and the cooling vanes around the perimeter with rustoleum silver. I like the hub area being black because it makes the rotor surfaces stand out more.
