OEM Carbon Fiber dash separating
The carbon fiber dash is coming up where the fiber meets the bright trim at the top of the gauge binnacle. This cf was installed at the factory and not aftermarket. Has anyone else experienced this?
Sorry for the goofy thread title. I can't edit.
If I'm understanding your description, mine doesn't sit perfectly flush either. Not enough to bug me.
Received 7,752 Likes
CORVETTE TODAY Host
St. Jude Donor'15
TPA, I would definitely take it to a dealership and see what they say.
By the way, I fixed your title of your thread for you!
Thanks Steve! Yes one side is definitely worse than the other. Apparently I'm not the only one experiencing this. I'm wondering if I can take care of it on my own with some glue? If not, I'll see if the warranty will cover it.
Received 1,694 Likes
St. Jude Donor '15
For something like that I would be inclined to get the dealership to fix it. If they can't, push for a new dash. Good luck!
Received 1,762 Likes
Man don't do the glue stuff yourself. Take it in and let them get you a new piece then let them put it in also. If you glue are do something with it they will blame you and may have to buy a new one on your $$$.. Robert
picture?
Can someone please post a picture of this problem!
It will get replaced by dealer with no problems as long as it is under warranty, had mine done and a friend of mine
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
Landru (03-15-2017)
Exact problem I and my friend had, dealer replaced it
I have the same problem, tried to fix with 3m red double face tape, didn't help. I rarely see it, the steering wheel hides it from me. Not really noticeable from the passenger side.
