ZIP removable front plate
Old Apr 16, 2017 | 12:50 PM
GT2BHPPY's Avatar
GT2BHPPY
Default ZIP removable front plate
Does anyone out there have any experience with Zip's removable front license plate bracket? Or any other vendor's removable bracket?
Old Apr 16, 2017 | 02:53 PM
triplblk91conv's Avatar
triplblk91conv
I just got one, kind of pricey but very good quality, fits on the grille
pretty easily, and it's on there tight...doesn't move or wobble at all.
So far I think it's the best solution if you want to put it on or have it
off for show, pictures, track day, etc. Removal takes only seconds.
Old Apr 16, 2017 | 03:47 PM
GT2BHPPY's Avatar
GT2BHPPY
Thanks for the reply, lots of lookers only one reply.
Old Apr 16, 2017 | 07:23 PM
traronf's Avatar
traronf
I have it, quite honestly I keep the plate on it and in the trunk. With practice it's fairly easy to put on but a little pricey. You need to make sure it is secured. The only alternative that I know is the motorized hidden plate that I have seen advertised.
Old Apr 16, 2017 | 07:28 PM
JonMN's Avatar
JonMN
^^^ I keep mine in the trunk too. Very easy to install if needed. just as a precaution I added some small pieces of paint protection film to the few places it contacts the grill.
Old Apr 16, 2017 | 07:34 PM
traronf's Avatar
traronf
Good point I used black tape on mine.
Old Apr 16, 2017 | 08:25 PM
TEXHAWK0's Avatar
TEXHAWK0
I just trimmed down the factory aero panel to the size of the plate and drilled access holes in the plate just big enough for a phillips screw driver, so it is easy to remove the fasteners without having to remove the metal plate first. Looks as good as any aftermarket bracket. Also, I think retractable plates may be illegal, for obvious reasons.
Old May 5, 2017 | 04:33 PM
MichaelO's Avatar
MichaelO
I have a nicely modified front plate bracket that I don't need. It's a guick removable from Innovative Products which I modified and added a small metal frame to take the curse off the raw edges. I have $200 into it, it's yours for $100 plus shipping. See the pictures, it's really perfect for someone wishing to easily remove their plate as needed. Let me know.
Old May 6, 2017 | 05:06 AM
undercooked chicken's Avatar
undercooked chicken
I have the same thing and it works great for my Z06. Goes on/off in seconds.
Old May 6, 2017 | 05:34 AM
MichaelO's Avatar
MichaelO
Notice the frame I put on mine. I had to modify the original to accept the frame. I know, they said don't put on a frame. I believe that was because it wouldn't fit properly without doing that modification.
Old May 6, 2017 | 07:36 AM
F4 Phantom's Avatar
F4 Phantom
Can anyone find the thread about the motorized front plate that folds under the front bumper and disappears? I was looking for it the other day and couldn't find it.
Old May 6, 2017 | 07:55 AM
MichaelO's Avatar
MichaelO
IMO, sits too low and is unreliable:
https://www.corvetteforum.com/forums...nse-plate.html
Old May 6, 2017 | 12:52 PM
F4 Phantom's Avatar
F4 Phantom
You mean it sometimes doesn't work?
Old May 6, 2017 | 01:42 PM
MichaelO's Avatar
MichaelO
Yes, I've read that it's operation is not reliable in the long term.
Old May 7, 2017 | 06:01 AM
undercooked chicken
Product Image Gallery
C7 Corvette Z06 Removable Front License Plate Mount
These are supposed to fit Z06 C7 vettes only.
Item Name:
Item #:
C7RLPFFL
Price
$179.00
Average Rating:
Old May 7, 2017 | 06:35 AM
patentcad's Avatar
patentcad
James Bond uses those you know. If it's good enough for 007, it's good enough for me.
Old May 7, 2017 | 07:45 AM
DAFFYDRUNK's Avatar
DAFFYDRUNK
I was at an Arby's one day getting my fill of grease when a guy pulls up in a 13' 427. Scrape goes the fancy motorized license plate bracket as it got crushed by a parking pylon. The guy spent about 15 minutes trying to bend it back into shape. Even if it was mechanically reliable, it's gonna meet its maker via parking pylon.
To ZIP removable front plate
