Audio Pilot radio volume adj?
Old 04-24-2017, 12:43 PM
bobs-z51
bobs-z51's Avatar
Default Audio Pilot radio volume adj?
How do you set the auto sound levels? could not find it in the manual, At settings, than radio, it only has a selection for on and off.
Old 04-24-2017, 12:58 PM
Rooster OG
Rooster OG's Avatar
Received 1,694 Likes on 1,240 Posts
St. Jude Donor '15
Audio pilot is either on or off, there's no setting the levels.
Old 04-24-2017, 01:40 PM
defaria
defaria's Avatar
Received 1,203 Likes on 732 Posts
This might be enlightening... http://gmauthority.com/blog/2014/11/...ure-spotlight/. BTW that took me literally 10 seconds to Google...
Old 04-24-2017, 03:37 PM
l.i. bruce fan
l.i. bruce fan's Avatar
Does anyone else notice that Audio Pilot seems to end up lowering your volume? What I mean by this is, for example, I turn Audio Pilot on at a stop where I set the volume manually, it raises the volume as I drive, but at next stoplight the volume is lower than where I started off at, and usually too low to enjoy or even hear what is playing.
Its a shame too, because its a feature I would really like to use in the Vette where the variations in engine and road noise, etc. is very pronounced.
Old 04-24-2017, 03:53 PM
Old Yellow
Old Yellow's Avatar
Yes.
The system sucks. Auto volume control worked much better. If you can hear it when the car is stopped, it's too loud when moving, and vice versa.
I just leave it turned off. It's less annoying to just adjust the volume as needed.
Ed
Old 04-24-2017, 04:02 PM
NSC5
Support Corvetteforum!
NSC5's Avatar
Received 1,100 Likes on 742 Posts
I ended up turning mine off also. The original GM speed sensitive volume system was more noticeable in operation but the overall results were better than I have found with the Bose audio pilot system in my Z06. Audio pilot seems to work a little better in my 2014 Cadillac ATS but that is a much quieter environment and there isn't as much noise level variance across equipment groups on that platform so it has an easier environment there.
Old 02-08-2019, 10:51 PM
Pat Schirtzinger
1st Gear
Pat Schirtzinger's Avatar
How to set volume on my c7
Old 02-09-2019, 07:59 AM
Frodo
Frodo's Avatar
I have my audio pilot set to ON and hardly notice the changes anymore. So that prompts me to ask myself if I'm just "sound blind" to what's going on or not. Do I have my volume level higher than many and not getting much change in volume as I stop and go? Or are some others setting their volume low and notice greater changes in volume as they slow to a stop? Is there a good deal of variance in it's performance from one car to another, from one platform to another (base vs Z06, NPP vs non NPP). One thing I have noticed is when the volume does drop at a stop the fidelity goes to hell. It sounds muffled, some frequencies seem to disappear. Fortunately for me I don't do a lot of stop and go driving.
Old 02-09-2019, 11:07 AM
JMII
JMII's Avatar
Received 2,023 Likes on 1,348 Posts
Originally Posted by Old Yellow
The system sucks.
Correct. The problem is two fold: 1) the stereo can't get loud enough to compensate due to the weak amplifier and 2) the system automatically rolls off certain sounds (bass / low frequencies) as the volume increases in an effort to keep the speakers from distorting. I find it sounds better when turned off.
To Audio Pilot radio volume adj?
Quick Reply: Audio Pilot radio volume adj?
