Paint Protection Film shows dirt on leading edges
I'm not sure if the film is XPEL or ScotchGuard or something else.
I just acquired a used 2016 3LT/Z51 Auto Coupe with film over most of the car.
I expect it will protect the paint fine and looks clean but have noticed that my bright yellow car has dirt lines on the leading edges of the panels where the film is installed.
This car only has 2200 miles on it and I hate to think that this will continue to get worse over time without intervention.
Is this to be expected. I guess I now expect it but hoped not to.
Has this happened to you?
Is there a way to clean the dirt off of those edges while not removing adhesive where it will peel up? I thought that alcohol would probably remove both the dirt and the adhesive so don't want to start that.
Based on your description, appears the original installer did not wrap the PPF edges, instead leaving a edge that will catch wax/dirt. The fix is easy. Xpel sells product specifically to clean and protect their PPF.
Not necessarily. Even on a wrapped car, there will be some edges. And yes, can be cleaned, needs a little detail work. Can also be avoided a little based on cleaning techniques.
what can happen is if the installer installs the film over an edge, like where the doors transition from the bottom to the middle, there is an edge there. If the film goes just ever so slightly past that edge, usually not noticeable by the naked eye, dirt collects in there because it is adhesive. There is no good way to clean it because the dirt is stuck to the adhesive, it has to be cut lower than the edge.
FL Events Coordinator
I had the same problem...spray some detail spray on the edge and use a micro fiber towel with you finger nail inside and it will take the white from the leftover wax off.
XPEL Paint Protection Film Cleaner is designed to extract most environmental deposits such as tar, oil, hard water stains, bug acids and other contaminants from Polyurethane paint protection films. Its deep cleaning action restores the clear, glossy, freshly-installed appearance of the original film.
Now if there was a touch up adhesive I could apply to the edges when cleaned, that might solve the problem for go-forward maintenance for years.
Just talked to XPEL. They said if the edges are compromised, that it was probably an installation problem. A qualified installer can use a (laser knife?) to cut those edges back. Once this has started it is likely to get worse.
Things like this are exactly why I avoid the stuff. I will take a rock chip or two vs. all this "installer error" finger pointing and risk of deterioration like this down the road.
It's all the rage right now, I get that, but more trouble than its worth to me. To each his own. Guess I'm just old school. Defensive driver.
Supporting Vendor
An installer can use an Olfa Knife (razor knife) the trim any excess film or an edge that is incorrectly done.
Had this problem on my yellow C5 with 3M film.
Could not get the black dirt out of the edges no matter what I tried.
Tooth brush, cleaners, etc.
This is why I will never have film put on my C7.
