Memory Seats - Auto Exit
Here's what my '14 M7 is doing: When I get in it the first time to drive it and leave the fob in my pocket and open the doors, the seat and steering wheel move to the exit position automatically. As soon as the door is closed, the seat moves to the driving position.
When I shut off the car and open the door to exit, the seat moves back to the exit position by itself. All is well up to this point. The problem starts when I go to get in the car the next time. I approach the car and the seat is still in the exit position BUT as soon as I open the door, the damn seat moves to the driving position requiring me to manually move it back to get in. Shutting the door this time, the seat stays in the exit position that I just manually put it to. Now I have to manually move it forward to drive the car.
Is anyone else's car following this particular sequence of events?
Doug
Doug
Doug
Doug
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
Doug
Doug
However solved what I called the "Superman seat option-you have to be faster than a speeding bullet to use it. " in the first few weeks from a forum post.
Been a long time but I recall you have to set to OFF an Enter/Exit option. It is the reverse of what you logically would think would be the way to set it from the menue words - but these were stupid errors IMO. (Not fixed until the 2016 software; and no upgrade with that "Superman" option out.) Can't recall exactly but set the seat return the opposite of what appears logical and the seat will stay in the exit position.
Thanks for your help
Doug
As stated, I never had the "optional" software installed in my September 2013 built C7 because it wasn't offered until some 15 months after I got my car and I used a two hand method for 3 1/2 years. In fact GM did not call it a fix, as IMO it was not! It should have been like my C6 standard shift where I pushed the start button only once!
As mentioned above it's not a fix to solve your issue it's what you have selected to either Enter/Exit. Look at the menue and whatever you have selected set to OFF. As mentioned a Forum member in October 2013 showed how to solve it! That is when I got mine to stop! Might be able to find a post, but as I said, just set it for what does not appear logical from the menue words!
It was addressed in 2016 and my 2017 does not offer that irrational option. That new software is not a dealer upgrade.
My 14 M7 did the same thing. Open the door and the seat would move to driving position. Had the software update performed and it added a third option in the menu.
Now the seat does not move when the door opens. It moves into driving position when you hit the start button. (Must have parking brake set for it to work)
FWIW, never had the software "option" installed in my September 2013 built 2014 C7, M7. Stoped the "stupid" seat moving to driver's position when the door is opened in October 2013, ~2 weeks after I got the car following a Forum post on how to do it!
From what Post # 21 describes, he has the "optional" software. Just needs to set Exit/Enter properly, IMO. Suggest your's is, perhaps by the dealer who installed the "optional" software.
Cruising
Hi, would you mind sharing the memo. Just bought a 2016 and tried following the manual to no avail. I would much appreciate seeing the memo or if you could refer me to a site location. Thanks, Craig
