Damaged my C7 today!
Hopefully your insurance doesn't take too large of a hit given your past driving record.
E-Ray, 3LZ, ZER, LIFT
Received 9,606 Likes
believe it or not, TC was actually on....sudden throttle application as mentioned here, sports mode and a small area of water in the street immediately before I pushed it did the trick, only took one second! the rear wheels jumped to the curb on the right then whole car slammed into a bus in the left lane next to me....
My Street Rod with an 8.2 Liter big block only has Positraction. When making a 0 to 60 run if one tires looses traction because of slight differences in pavement you have about 1/2 second to lift or it will steer in the opposite direction from the wide rear tire with traction and you'll be in a ditch!
There are YouTube video's of where folks turn off the nannies and the car instantly goes off the road when it shifts etc.
elegant (05-25-2017)
Something that is always on my mind when im driving around; try like hell, not to show off and do something stupid. Just last week on the interstate in traffic, I had a young kid in an old Pontiac TA come up next to me reving his engine, when I didn't bite, he tried smoking the tires and almost lost control 2 cars in front of me. My wife was shocked as he almost slammed sideways into the car next to him. I may be getting old (41), but my Z06 scares the crap out of me!
vbdenny (05-26-2017)
I feel for the guy--most of us have been there too and nothing hurts more than self-inflicted car damage. If you didn't hurt yourself or someone else, then that's the main thing.
Traction control isn't predictive so it doesn't react until there is an actual loss of traction and with a lot of power on tap that split second of lost traction can cause a major vehicle reaction. Weather mode comes closer to predictive behavior because the increase in power delivery is slower with increased throttle application compared to other modes and TC is set to intervene at a lower threshold so control won't be out of shape as badly when TC and Stabiltrak intervene.
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
IMHO, it looks worse than it actually is. The more I look at the pics, the more I think you've got to replace the front fender only. I think the rest might just be repairable. Depends on how good the repair shop is with Corvettes.
As for this being your last Corvette, that depends on whether or not the bug has bitten. I know in my case I tried going without a Corvette for 12 years. Then I just had to have those crossed flags parked in the garage.
Regarding turning it in at the end of the lease, could they go after you or your insurance for diminished value? Might be a good time to review your lease agreement to see if there is any mention of this.
Go to YouTube and search c7 corvette crash--you will find many videos of drivers losing control on dry pavement, and you can almost always assume they turned traction control off. As for the OP, that car's almost certainly repairable.
and despite internet myths and Hollywood dramatizations, catching something that is loose on the street is really hard- really hard. Much harder than the track.
First, it's unexpected. At the track, I feel it before it happens. I know I'm driving at the limit so I'm on high alert.
Second, you have about 15 ft + wall/car at the other end rather than 40ft and runoff. When **** goes bad on the track, I can straighten out the wheel a bit, go a bit wide and regain traction. On the street, I'm already in another car or into the curb.
And last, traction control basically makes it impossible to correct anything. If traction control didn't stop it, there is virtually no chance of saving it unless you just get lucky. edit: this is not to say TC on the street is bad. It's virtually your only chance given how little time and space you have to react.
Received 8,919 Likes
my insurance deductible is just 200$, so probably a big insurance hike coming soon! this is my first accident ever! I am 40 years old and never had a single incident though, got out without a scratch. honestly, it wasn`t a hard impact...almost zero damage to the bus, couple of scratches. I stopped expecting small damage but when I got out I was shocked to how much damage was on the car side! I guess all that fiber glass/plastic is super easy to crack!
this is probably my last corvette! next will probably be an AWD like an R8....very unlikely this would happen with any AWD car! now i am driving around in a crappy small jeep rental for a good part of the chicago summer! will probably just fix it and turn in into the dealer soon after....
Make sure you don't have damage in another location. Yesterday, my wife was hit in the driver's side rear while driving our Terrain. It was more a less a low impact hit that ruined the rear fascia and pushed the dual exhaust system down. However, while walking around the car I noticed the gas filler cover on the passenger side was open. When I tried to close it it moved around unlike it had ever moved before and it took some effort to latch the cover. That cover and its hinge is at least 5 ft from the point of impact and is located on the opposite rear quarter panel with an empty cargo area between the two points.
Bill
#34
#35
Received 3,970 Likes
To be blunt...
So, after you admit spirited driving, in traffic, after hitting a puddle, resulting in you hitting the right curb and bouncing back into a bus, this is somehow the cars fault?
This sounds like it had more to do with the Indian than the arrow, and an AWD R8 is not going to improve your situational awareness. Sounds like you might be better suited for a Q7 than an R8.
Better yet, maybe just Uber it from now on.
SloboGS (05-26-2017)
#36
#37
Sounds like cold tire syndrome - in addition to the water. My A8 Z51 tried to bring the rear around on a 90 degree turn a few times in 40-50 degree weather after being driven less than 2 miles. Lesson learned.
#38
Received 3,818 Likes
I am VERY glad to hear you're ok...But you lost me when your reaction to this accident is "this is probably my last Corvette".
#39
Received 2,639 Likes
Hate to see that Sam, but you're OK and no one else was hurt. That matters. The car can be fixed, and a lesson was learned. It's all good.
BTW, you're right. The insurance company will bent you over. It doesn't matter how long you been with them, and how good your driving record is. I know this from experience from a minor mishap the wife had.
#40
Received 1,738 Likes
St. Jude Donor '15-'16,'18
