Painting GS hood air induction
I am in the process of putting GS stripping on my GS convertible. I kick myself for not ordering the stripes when I ordered the car, but too late. I have the white stripes, but now need to paint the air induction grill for the hood. Has anyone done that? The body shop I talked to was not sure if they could paint it because I couldn't tell them what kind of materials it is made out of. I didn't think it would be that complicated
Any suggestions on getting it painted?
Thanks for any help or advice.
I had my stripe added post delivery too. The dealership simply took off my hood vent, painted it, and reinstalled it. It looks great, no problems at all.
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
After masking, they painted the flame area black, I would have that be carbon flash. Then they used 1/8 inch masking tape over the black at the edge. When dry they painted the darker silver. That left an 1/8 inch black boarder. They then cleared over the finished flames - can't feel anything. Just a thought since your considering having the hood vent painted you might want to consider that approach with whatever edge color fits you car/strip colors.
The vent is painted carbon flash now so should be no problem. They will probably use an epoxy primary.
DakotaVette (05-20-2017)
Should not be an issue sand paint and clear
JerryU (05-19-2017)
I think the body shop is afraid there will be some flex in the piece and the paint will crack or not stick.
I think if I explain that, they feel a little more comfortable. I am going to take the car over there. I couldn't understand why he seemed hesitant about it, but they do guarantee their work for the life of your ownership.
Received 19,219 Likes
'20-'21-'22-'23-'24
Color of painted hood vent
Good morning. I am planning on having the hood vent painted after my stripes are put on next week. I am just guessing, but was the color they painted your hood vent the 2017 Artic White? Seems logical if you can't order a white stripe with a white (artic white) GS.
Yes it was and it is a perfect match to the decal stripe.
My car is admiral blue with a factory shark gray stinger. I ordered some shark gray paint form a paint specialist who used GM code to mix up the paint. Well, the paint didn't match at all - it was way to dark. So, I took the car to a local body shop where they used one of those paint match cameras. The color they came up with matchs perfectly. Trying to match paint to a vinyl decal can be difficult.
Since you can order cars with the body color vents, you could just order one already painted the correct color and change them out.
I don't really like the body color accents on the fender vents, so I thought about ordering the all black ones and just swapping them.
