7 speed manual-1st gear engagement
Did you read my post where I wrote where this "issue" has been around since at least 1994 in this series of transmissions? This is nothing new, nor is it anything more than "minor", unless you really have a shifter rod that's out of alignment. Since yours didn't improve, I really doubt if another dealer is going to be make any appreciable difference.
I know this isn't what you want to hear, but trying to give you some perspective.
Have a good one,
Mike
Have a good one,
Mike
Have a good one,
Mike
Have a good one,
Mike
I have contacted Chevrolet Customer Service and they are actively pursuing resolving this issue. Hopefully, they will give authorization to the dealer to find a solution to the problem.
!st have the dealer use the transmission oil check tabs ( they use to check fluids with oil-brake etc ) !! Does it slip out using REV Matching ??? The only time I have a problem is when I have the seat too far back and I haven't pushed the clutch pedal in far enough to shift !! Only other car I had a problem with the clutch was the throw out bearing on my 1967 GTO ( I have owned 6 other manual transmission cars ) !!!! Wayne
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
He very politely said it was not and mentioned his biggest problem with customers when he asks on the phone for the problem symptoms, they tell him what they think the problem is, emphatically! I just made a suggestion and was NOT emphatic!
Turned out it was the computer that was not processing the outside temp properly! Tech sent diagnostics to BMW and they had a quick answer, need new computer. Fortunately it's covered on warranty. They did the 2 year brake fluid flush and changed oil which was close to being needed. That was $1900 also on Warranty. We'll see what the "computer costs" when it arrives. Several weeks ago they changed wiper blades that was also covered on Warranty (3 allowed per year.)
Have had a new drivers side airbag and a new $900 battery all on a recall and paid for on warranty. Actually the car has run perfectly other than this intermittent check engine light!
If it needs brakes in the 4 years that are covered they are also replaced free on Warranty.
Sure we paid for it in the price of the car! At the end of 4 years we'll buy a new X5. Cheaper than repair costs!
That said, your comment may be correct and if the OP has had the clutch fluid changed, then it's probably a none issue. If not, I'd sure have that done before following your advice! Many posts on erratic clutch performance due to dirty fluid. Depends when a dirt particle gets in one of the small passengers!
Reminds me of what I always joke (with some truth) about; the 4+ open heat surgery teams we have in two large competing hospitals in town! If you get indigestion while passing through on I95 or are in Myrtle Beach some 60 miles away, they will bring you to one of those teams who are prepared and you'll have a 4 way bypass in a few hours! Perhaps better to take an antacid first!
When I first got my 2014, I had a little trouble feeling when it was fully engaged, but once I changed to aftermarket shifter, there is no uncertainty anymore.
I have a Core Shifters modified Hurst shifter (Hurst components, not billet shifter) which seems to be the perfect combination of short throw and minimaaal shift effort in higher gears.
It definitely feels like two detents, and clicks twice when going into gear.
If it actually pops out of gear, as pointed out already, it never hurts to make sure the shifter is aligned correctly... There is actually a service bulletin on some that were not from the factory.
The shifter alignment is not that involved if it is similar to the C5, C6. Once I became familiar with it I figured out that removal of the console was not really necessary and I could do the job in 30-60minutes. I probably did it every month or two and it did make a difference.
The clutch fluid should be done periodically anyway, and it might help.
Lastly, the transmission lube should be changed periodically.
The shifter alignment procedure is probably in the service manual, and if you don't have that, look in You Tube.
Finally, got the second dealer to re-perform the Bulletin #P22376D and it solved the problem! It not drops into 1st gear easily and the shifts to the other gears require less effort than before! The tech at the second dealership said that the linkage adjustment was very critical to allow easy engagement. I had to pay the second dealer to perform the adjustment as it appeared the first adjustment was not precise enough. I went back to the original dealer and they are agreeing to refund the fee for their improper adjustment! I feel much better, but still think I should not have had to pay for this as it is a known defect from the factory.
Get this shifter and you will be even more amazed.
#33
That comment remind me of my visit to the BMW dealer the other day for an intermittent "check engine light" flashing on. At 25,000 miles on the wife's car told the Service Writer I thought it might be the brake fluid level being low. To check you have to remove the full width plastic leaf gill that covers access!
#34
I had this problem intermittently on my 2007 MN6 C6. I could be quite startling when it jumped out of gear, but I always thought it was just operator error and that I hadn't engaged the shift lever in far enough. Then at around 185K miles, I lost 5th and 6th gears which resulted in a nice $5K replacement of the transmission. My work and love life caused me to do ALOT of long distance commuting, and I am pretty sure that using overdrive all the time caused my high gear bushings to fail, and for a short time I was driving a 4 speed C6! I have not experienced this issue on my 2017 GS, but I only have 2K on it at this time. Who knows?
#35
As I said I'll buy a new one at the end of the 4 years, it's cheaper!
We have a large SUV, would not worry about the battery cost when buying a BMW you can get ones that fit cheaper. But other OEM parts are high as are Porsche etc. they do give a great warranty, granted it't in the price. My battery was operating fine, they changed it for their own reasons having to to with their semi regenerative braking.
#36
I opened up the tranny and found that the splines on the 5/6 shaft were completely fretted away.
Currently my C5 has 280K+ miles on her, no problems with the transmission at all (other than the typical 1st gear engagement issues that's the original topic of this thread).
So, it happens, but doesn't seem to be related to shifting into 1st.
Have a good one,
Mike
#38
I have the 1st gear shift engagement problem on my 2018 Z. So I will see if the dealer knows what to do. Actually I might do it myself now that I have seen the TSB.
#39
I had heard that some had gained results by installing the MGW shifter, so I decided to go that route! Again, more improvement, but still the occasional "extra hard push" to get it to fully engage.
I saw that some had luck with using Redline D4 ATF Synthetic fluid, so I took it to the dealer and asked them to change the fluid for me.
That's when they told me that if I used anything other than GM Dexos fluid, it would void my warranty! They, like the first dealer, said there is nothing further they can do! Obviously, warranties are not what they used to be!
Bottom line, I told them to use the Redline D4 ATF, warranty, be damned! So, the transmission is MUCH better, but on occasion I have to push a little harder than usual to get the gear fully engaged.
Although I would have liked to have completely resolved the issue, but it is so much better than before I started making attempts to fix.
The best part of the exercise was installing the new MGW Flat Stick Shifter and it is as advertised! Excellent product and the DIY Videos were the best! Also, the Redline D4 ATF added to the smoothness of the shifts. At least I am enjoying my C7, again!
#40
Well, the saga continues! A few days after I posted that the problem had been resolved, I started to experience some resistance again on various occasions.
The following 4 users liked this post by sccaracer46:
