Dealer sold me a tuned car which now has a voided warranty, what should I do?-Texas
I would just want to be sure that the aftermarket warranty would not red flag any issues in the future because of the tuning that was done and/or reversing of tuning. I'd want to see that in writing....
Once tuned, there is no going back and the engine part of any warranties are no longer honored. The fine print of any warranty defines never altered from OEM specs.
I'd sue and demand a full refund, and in the future run a VIN check with a dealer on any used car you're considering.
NSC5 (05-25-2017)
Be very careful about accepting the deal which sounds good on the surface. An aftermarket extended warranty may not offer you any protection as indeed it is an extension of the manufacturer warranty. Before accepting the offer, read the warranty they are offering very carefully. Otherwise, you may end up with false confidence in the coverage you can expect.
NSC5 (05-25-2017)
Do your homework on this.
Honestly, I think you should bring the car back and get your money back. There are tons of unmodified garage queens, as well as discounted new ones.
I hate to tell you this, but in the case of an engine problem, any after market warranty company is going to check for a warranty block before approving your claim. Moreover, flashing it back to stock will not hide the fact that it was once tuned because the fingerprints of the non-OEM tune will remain on the ECU.
I would take the car back and give the dealer 2 options. First, they can give you a full refund and make you whole again and take the car back OR they can speak with your lawyers.
I would start with a simple asking them for a refund. If they become defensive or flat out refuse, then bring up the lawyers.
Do not make idle threats though. Do not get upset with them. Simply leave and get a lawyer. Follow through and fight it. Recommend to the lawyer to go to the state and report the incident.
Maxie2U (05-25-2017)
The offer will certainly be less of a headache for the dealer, but your headaches will continue. They are looking at an easy way out of the deal they know was not right.
Received 2,639 Likes
As you say the V4 mode is not working it could be something as simple as someone installed a Range plug in device that disables the active fuel management system. It plugs in the OBD port under the steering wheel. There is no de-tune necessary, just pull the thing out.
You may want to check this before the dealer tries to remove a tune that ain't there.
Here's the info.
https://www.rangetechnology.com/pages/v4
Here's the info.
Here's the info.
Here's the info.
#33
I would not take this deal. Aftermarket warranties are generally crap....especially on a C7 Vette. If you are concerned about having a warranty, figure out another deal with them. Trust what the forum guys are telling you.
#35
M7 correct? If you like the car, and plan on keeping it past it's original warranty, how about asking them for another $4k off to cover repairs that would normally be under warranty? Of course, the problem with this is you will figure out the markup on the warranty, which is probably damn near double. Maybe take $3k and keep the thing?
#36
Location: Pottsville, PA. USA Home Of America's Oldest Brewery Yuengling
Received 2,239 Likes
With all the C7's for sale why buy a problem child? Take it back for a refund or have them get you another car? Lets say in a year or two you want another car? You are going to have a problem selling or trading this one? Get out of it now!!!
#37
I see from one of your posts that the car in question is a M7. It makes absolutely no sense with the manual transmission to have a tune just to get rid of V4 mode because the manual only goes into V4 mode if eco mode is selected. And you wouldn't select eco mode unless you wanted it in V4 mode. So unless the previous owner was clueless that tune is doing more than just removing V4 mode.
probono (05-26-2017)
#38
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,821 Likes
2015 C7 of the Year Finalist
So.... The real questions are:
Does the car go into V4 mode when you switch to ECO.
Does the car NOT go into V4 mode in the ECO mode?
What the heck was tuned?
Elmer
Rebel Yell (05-27-2017)
#39
#40
Received 2,481 Likes
St. Jude Donor '15
"In honor of jpee"
^^^I don't know what was or wasn't tuned out, but it doesn't matter. OP, you are screwed unless you can get all your money back. All. Not some. And the deal you're going to get on another car will just put you more in the hole. This is an unscrupulous dealer who sold you a car, told you things that they know weren't true (or worse, didn't know, but said it anyway to sell you the car), and now is going to soak you for another warranty that is not a warranty.
As nsc5 said, and as I can see from your post you came on here AFTER you bought and noticed you had a problem. You have an as-is car. Period. If the engine, trans, diff, or etc. goes, it's all on your nickel. Your pockets.
Again as nsc5 said, if 'we' the used car buying public don't know to, or decide the seller is "a good guy and looks honest" and we DON'T CHECK the VIS report which may show a tune, a warranty block, a warranty denial (from any GM dealer svce. dept. FOR FREE), then sorry to say, it will be on your account of not doing due diligence. The words to remember are caveat emptor. You are the buyer, you have to beware.
And no lawyer will work for free, so you'd better hope this lousy dealer gives you back all your money. But I doubt it.
About the only good to come out of this are the tens, or hundreds of people who read this and say, "I never knew I should check about a warranty block, or a known tune. Maybe I better do that next ____when I go buy a used Corvette." FILL in the blank with : week, month, year.
Good luck, corvlegaladvice. Tell us how it all turns out for you. We're hopeful, but realistic, too.
Walt White Coupe (05-25-2017)
