A8 Transmission failure tracking
#281
Flutter Back after Triple Flush 7/28/17 2015 CP Z51 19000 miles. Back to the dealer Thursday
Update turned out to be engine misfire and cylinder deactivation codes and not torque converter.
#282
Not surprised, magic potions only work in JK Rowling's books.
A new converter and a Range module or manual mode shifting to avoid V4 operation and a recurrence of the problem are about the only real cure at the moment.
I love the performance of the A8 (8L90) in my 2016 Z06 but it will never see V4 operation.
I was seriously considering a GMC 1500 series pickup this time since it is available with a crew cab and standard bed now but with all of the V4 mess it looks like another 2500HD with Duramax for me. I guess the extra profits GM makes from that pickup will help them cover torque converter replacement costs for others. Given the various risks of problems I would rather chance problems with the diesel emissions system in order to avoid V4 mode issues and the Allison 1000 transmission is about as close to bullet proof as you can find.
#283
Here's why. Chevy has been selling low end cars too long. Porsche, BMW, Lexus, ect. wouldn't dream of treating their customers this way. Corvette's should be sold out of Cadillac dealerships. Their customer service is several steps above Chevy. When you purchase a car that starts at 60K and can go over 100K, the dealer should have craftsman mechanics who know every inch of the car instead of parts changers and a direct line to the engineers who know what the hell they're doing.
You shouldn't have to wonder if the dealer MIGHT give you a car to use while yours is being repaired and to make up for the problems they should give you hundred thousand mile bumper to bumper warranty. I loved my Vette. But it wasn't worth the aggravation so I lost 20K and traded it in and I will never buy another GM product.
#284
Fine work mountaineers
[QUOTE=mountainears;1595347037]I'm not sure there is enough evidence to warrant putting a purchase on hold, but do what you feel is right :-)
If I was buying now and not totally interested in a M7, I would still consider an A8. There are TONS more people that have not had a problem than have had a problem.
I'd purchase an extended warranty for sure, once I got towards the end of the factory warranty to protect myself. But I wouldn't let the issues going on get in the way of the purchase
#285
So it sounds like the problem is stemming from the continual transition between V8 to V4. Is it correct in saying that the only way to avoid this problem is to keep driving the G S C E in manual mode?
I haven't noticed if there is a certain build date where this problem seems to appear and disappear. What are your thoughts on this?
#286
Cruising
A8 transmission problems
#287
As Motorman said, it's a corporate issue, not just one linked to Corvettes.
#288
Why GM does not offer alternative transmission
A number of posts in this thread have raised the question of why GM does not provide a different trans or allow disabling of afm. The reason, I believe , is related to emission and fuel economy certifications. They in essence would be violating federal law. Just like adding aftermarket headers that impact the oem catalysts. Legally you cannot alter any component that impacts the certification process.
Preston7 (08-18-2017)
#289
4th Gear
Maybe they have? Will be interesting to see if we continue to see reports of this or if with revised parts (that have been described in this and other threads) as well as service procedures, this will start to be a think of the past.
Just because a recall or TSB isn't issued doesn't mean they are not working on it.
#291
Received 1,738 Likes
St. Jude Donor '15-'16,'18
#292
Once you car has been repaired would you please post the part number coming off and the part number going on as well as the part number of the fluid that will be used if required. That would be most helpful for those of us who have been tracking this problem for almost 3 years now.
If I may suggest, ask the service manager in advance of the repairs that you would like that information " for your records"
Last TC replacement on my 2015 the part numbers were not on my invoice and I had to do some running around to get that info, FYI.
Good luck.......
Preston7 (08-21-2017)
#293
Don't think for a minute GM is truly working on a fix for this..
As demonstrated, they will just try various parts/fluids while the car is under warranty, than delve into the actual fix which may cost them millions in re-working the engine or transmission..
Believe me, if its not a safety issue, this fix isn't coming anytime soon...
#295
#298
Got a emissions light a few days and got it read at a chain auto parts store. It cycled off though so thought nothing more about it till I took it in for service. It was running smooth by the time I got the service point but they drove it in eco mode for 40 and 15 miles tech and then service manager and could not reproduce the problem. Has ran fine since but installing the AFM Disabling Device tomorrow. Some say it makes for a smoother ride.
I also use a Top Tier fuel (Shell VPower) from a station that tests their tanks daily.
#299
2016 z51 issues...
GM approved my full refund buy back. Car still in dealers possession for now 2 months 4th time back. I called the gm customer service number per my service advisor fast forward almost 2 months, approval for full refund. It's really sad, they can't fix it, lemon law attorney can't help when vehicle is at dealer, but God is amazing and this massive debt and stress will soon be over. I've been paying for a car not in my possession but all will be refunded. Sticker was $85k, just glad it soon will be over. Good luck gents!!!
Brian in Bakersfield...
Preston7 (09-02-2017)
#300
I'm not sure I will fit into your survey. I have a 2015 Z51 Auto. It overheated the first time I took it to the track at about 1600 miles. I brought it back to the dealer and had all the fluids changed, about $475.00 for oil, transmission and diff. I was disappointed that the track star I bought really could not handle the track after all. I currently have about 7500 miles on the car with no other problems but I will not take her back to the track again. Too many stories like the others in this survey that are having serious problems. I put Z06 quarter vents and grill on and she will run all day (11 hours) between 150-160 degrees and 70-85 mph. She is a great GT car getting well over 30 mpg on trips but she is not a track star. Thinking about maybe getting a Porsche Cayman for the track but that is further down the road. Like I said this might not fit this survey but I do thank you for putting it together.
