A8 Transmission failure tracking
#901
A few details are dribbling out about the new TSB/fluid. I saw a GM letter describing the introduction of the TSB (but not the actual TSB) which was posted on one of the camaro forums.
I found this detail, ummm,, frustrating because of the lack of clarity.....
The old fluid is ,,,, Mobil 1 LV ATF HP
The new fluid is ...Mobil 1 LV ATF HP
To distinguish between the two, look for some kind of 'blue banner' on the bottle label and a Dexron license number J-62120 somewhere in very fine print on the back of the bottle.
That sure makes it clear to each and all which is the old and new!!!!! (not!)
(Mobil 1 LV ATF HP fluid I purchased in Oct 2018 has license number J-60193)
Get in line quick because new fluid is 'limited' to only 120 qts/week/dealer during the introduction phase.
#902
Re: DEXRON HP
The info is all in December's Emerging Issues in Center of Learning, course 10218.12V. Quote and bolded bits from the transcript below:
Due to the availability of the new Mobil 1 HP fluid and required tool kit, the procedure will be rolled out regionally starting in the Southeast and South-Central regions due to the frequency of TCC shudder. This concern is related to moisture. The current HP fluid has a greater tendency to be hygroscopic – or water absorbing. It also tends to hold that moisture even when the fluid heats up. As the moisture content in the fluid increases, the tendency to have TCC shudder increases. Selected dealers received a Global Connect Message sent to the attention of the Service Manager the week of December 3 advising them of the new service procedure, tool shipment and fluid availability. The Global Connect message includes a PDF copy of the service procedure. It is anticipated that the Mobil 1 Synthetic LV ATF HP and required tool kit will be available to all dealers by March 2019.
Mobil 1 Synthetic LV ATF HP will only be available through your local GM Oil Distributor. The new oil formulation will initially be available in 55-gallon drums. Drums will cease production in January 2019 and will change to quart bottles.
The quart bottle will not have a GM part number on the bottle. The bottle however has been updated. The back ground of the bottle where it states “Synthetic LV ATF HP” has changed from black to blue. (show bottles) The license number on the back of the bottle has changed to J-62120. The six pack packaging has been changed from black script on the white box to blue script on the white box.
Dexron HP Fluid, part number 19417904 for a 55 gallon drum or 19417577 for quart bottles.
The following 3 users liked this post by javenius:
#905
Received 3,439 Likes
#906
It feels like you are driving over rumble strips but doesn't seem to effect shifting or anything else. If you disable the AFM (4 cylinder mode) with a range device or a tune the transmission seems fine with no shudder.
#907
as posted above, feels like driving over the dots separating the lanes. Once it starts it will continually do it. If you pull the shifter into M (Manual) it should stop-mine did. Had the flush about 4 months ago-so far do good, but have only gone o one toad trip since.
#909
Yes, at first it feels like your running over a rough road, when it gets worse it will shake the steering wheel and feel like you just lost 4 of the 8 cylinders. Also check for the problem by setting your cruise control, say on 60, and watch the tach, if the problem is getting ready to happen you'll see the tach drop from 1-2 hundred rpm and then back. example: cruise is set at 1500rpm....it will drop 1 to 2 hundred rpm and back up to 1500rpm with no noticeable feed back from engine or you, but it will be continuous. I thought it was cruise control, its not! Thats the torque converter hunting.
speed4tu (01-22-2019)
#911
Thats what I'm wondering with the 19's. I was gonna trade my 16 Z51 A8 in on a 19 Z06 but the constant issues I've had with mine have left a bad taste. Considering a different brand now unless I hear something drastic has been done.
#912
I've had this issue and it's becoming very annoying.
I've had it in now for the 4th time at my dealership, dropped it off this morning. In December they told me in January they have a new PPD for the "torque converter fix" and, just like before, it's a "New" low viscosity fluid and a 'change in the procedure' of how they adjust it. Color me skeptical that this will fix the mechanical issue, if it does...fantastic, but not holding my breath.
I'm very close to escalating this further but I fail to see how a $73k car should feel like the worst drive I've experienced in my life. This is a known issue and the constant bounce back/deflection of the true problem is very disconcerting.
I hope this 'new fluid' helps but the new fluid didn't help last time. Now i've felt some slipping recently, and a P1035 code a month ago when the radiator fan stayed on. Issues are stacking up and my confidence in keeping this car any longer than my warranty that ends at the end of the year is lowering.
#913
Received 2,051 Likes
St. Jude Donor '13
The problem with GM's "fix of the month club" approach is that it can take a while to know whether the latest fix will really do the job. If you plan to buy a new A8 and keep it for a while, are you willing to roll the dice right now? I'm optimistic but far from convinced, and it will probably be at least a year before there's enough data or anecdotal evidence or plain old rumors, to have a firm opinion.
We certainly can't count on GM to tell us what's happening.
Maxie2U (01-24-2019)
#914
Probably the closest we will come to learning what was discussed internally is if the class action against GM over the 8Lxx transmissions moves forward and internal documents are obtained through the legal process. I suspect GM knows how to fix the problem but not at a cost they are willing to bear thus we get the "juice of the month" club approach.
The biggest winner from this approach is the competition but at least there are enough makers of properly performing automatic transmissions that GM alone can't sully the reputation of the product class like they did with their poorly designed 5.7 liter diesel back in the late 1970s which put a dark cloud over any passenger diesel introduction in the U.S. for many years.
#916
It sounds like it will to me, but only time will tell.
See Newguys post, a few posts up.
Mobil 1 Synthetic LV ATF HP will only be available through your local GM Oil Distributor. The new oil formulation will initially be available in 55-gallon drums. Drums will cease production in January 2019 and will change to quart bottles.The quart bottle will not have a GM part number on the bottle. The bottle however has been updated. The back ground of the bottle where it states “Synthetic LV ATF HP” has changed from black to blue. (show bottles) The license number on the back of the bottle has changed to J-62120. The six pack packaging has been changed from black script on the white box to blue script on the white box.Dexron HP Fluid, part number 19417904 for a 55 gallon drum or 19417577 for quart bottles.
rckt (01-22-2019)
#917
Yes. And there is another drive train issue that you have. Poor old GM can't get the main part of the car squared away. Absolutely appalling. I've been fortunate so far, but not going to get a head of myself and smug.
#918
Flush success!!!EXCELLENT! Just got 2017 Stingray back from dealer after the new flush,transmission oil, and reprogram. The transmission is perfect. No shudder, no hard shifts. It didn’t run this well when I took delivery 38000 mi. ago. Could not be happier. Thank you GM. It’s about time.
18 na - - -
18 na - - -
The following 3 users liked this post by Har-ray:
#919
18 na - - -
18 na - - -
