A8 Transmission failure tracking
#101
I've got the A6, so no skin in the game, but how long can Tadge Juechter just totally blow off this issue
A8 owners should be bugging GM until Tadge steps up to the plate. Why not start a thread in the Ask Tadge section, demanding this guy to admit the A8 is flawed with a promise to work on a permanent fix. Just my 2c.
#103
Thanks for pointing this out. I love these "Tadge should do this, Tadge should do that" posts. This is a GM ISSUE, not a Corvette issue. The A8/AFM combo was clearly not sorted when they put it into production, and the number of Corvettes affected is tiny compared to all the trucks/SUV's with this powertrain/drivetrain combination that have the same issues. It is truly sad that "new" GM is sure acting like "old" GM on this one.
#104
Maybe purchasing an after market trans coolers and AFM disablers and Transmission shifting software might be a more reasonalbe approach since GM could not get it right.
#105
Well, well, well, misery loves company. Does all this sound SO familiar.
We are currently pursuing litigation against GM for all this.
Replaced torque converter twice. "Metal in oil", replaced crankshaft, thrust bearings, oil tank etc
Tach jumps up and down at about 1500.
Complaints of 'jumping/lurching' never fixed. So we pursued a lawyer.
Went out the other day just to roll it back 8 feet to pressure wash the driveway and the transmission is locked up. Wouldn't budge a 1/4". Can't even roll it in neutral.
One glittery piece of crap.
2015 Z51
Oh, and "hello"
2015 Z51
Oh, and "hello"
d00d (11-08-2020)
#108
#109
Received 3,439 Likes
Yes, it appears most of the issues are a bigger GM issue, not a Corvette issue, both technically and in terms of their attitude towards dealing with the issues. However, the lack of cooling on the 2014/2015 is a Corvette issue. They shipped it knowing the problem existed and have done nothing to remedy customers. So I see no indication that the Corvette team's behavior is any better than that of all of GM.
#110
#111
Belt tension was replaced, which got rid of the metallic rattle from the video I posted. Problem is though, it still runs super rough on accel in v4 mode. You can still hear the belt shimmy and beating around in there, just working the hell out of that hydraulic damper.
The tech was very adament that at this point "that's how its supposed to be", but he also mentioned that he thinks some of that roughness is actually the knock sensor getting activated just by how much shimmy there is from the v4 mode. So the knock sensor stepping in and retarding the timing is probably the other shudder that I'm feeling.
Soooo how is that "how its supposed to be"?
I'm still getting the super-hard shift from 1 to 2, and sometimes when you put it into drive. Hard like it feels like you just got rear-ended.
#113
#114
Heard all that crap....then I realized I made a big ...sold the car ...no more ..dealership crap to listen to ...
#116
#117
My transmission had to be replaced to stop the super hard shifts and feeling like you were hit from behind GM knows this well!!!
#118
Are there any figures or % of these failures ?
It seems like it is happening way too often to me
Really puts the scare in me about buying any of the newer vettes with an auto. Is the A-10 doing any better ?
NSF
NSF
#120
There is no hard data for percentage of failures. But with that in mind, I have followed all threads on issues with the A8 Stingrays for quite sometime. There have been other threads that try to determine a percentage, etc. I would say at the most it is 5% tops that have developed some type of issue. Unfortunately it seems like most drivers don't put enough miles on their cars to get real good data. It does appear that once a car gets 15K on it there are no issues reported that I have come across. It seems to start to rear its ugly head with in the first couple of thousand miles.
I don't see how the A10 would be any worse, but you never know.
Clearly most owners don't have issues. I can say that for certain.
The following 2 users liked this post by joemessman:
Catsbilly (07-12-2017),
Not So Fast (07-01-2017)
