Nano Coating Worth it?
Received 3,439 Likes
My friend has a black c7 and I have to hound him to wash it. I go over to his place about every 6 mos and we wash it together. I have to sort of force him to do it. It looks as good as mine when after drying it. I detail mine every day and his looks just as good for the most part. I just like to do it. Too much time on my hands. These modern clear coats on cars really do the job. His is 3 years old and hasn't ever waxed it.
Some things never change.
A few weeks ago I spent 9 hours on paint correction and polishing. I then applied Kamikaze Miyabi Ceramic coating...The results were amazing. I never thought white could look so good..
-M
-M
If anyone had any nano or ceramic etc etc coating why don't you wax the car then take some masking tape and tape off that area. Then put this "super duper" coating on one side of the. hood. When you take the tape off you should be able to see if there's a difference. Anyone game??
No reason to go to all that trouble. I frequently wash my C7 (CQuartz Finest-coated) and another one of our vehicles (well waxed) side-by-side. The difference in hydrophobic qualities is quite significant. The waxed vehicle beads up nicely, but on the CQuartzed surface the water doesn't even have a chance to bead because it rolls off the surface so quickly, leaving a mostly dry surface behind.
I'm not going to say anything bad about these super paint coating. They might be great toward a super finish that last for a very long time that "might" resists swirls . "But" here's a couple photos I took in front of my house of my vette that's about 3 months old and was only waxed by the dealer prior to P/U. I don't know how it could shine anymore and per my prior experience I believe it will last many years through many many car washes......
dvilin (06-19-2017)
Your car looks great.....now.
But it isn't a shine issue it's a paint protection issue. These ceramic coatings protect against swirling which eventually dulls the finish. They provide protection from elements that build up on your paint, dulling it over time. Some people don't care and think a coat of wax is all they need. Its this way with all kinds of newer technology. Some people feel "their way" is good enough no matter what comes along that is clearly better, and these coatings are far better. I highly recommend having it applied or doing it yourself with the consumer version. I had my Vette done by a pro and it cost. me 750. I then did my Audi myself and it is no more difficult than traditional was but will outlast wax by many many miles.
Your car does look great, and there's no doubt anyone can make a vehicle shine w/ any old wax. It's the extra protection you're paying for with the high-end coatings, as well as the ease of maintenance over a long period of time.
Bondo here's my torch red after a fresh ceramic coat and boost. See the depth of the shine. It's the same angle and shot as yours. But the coating will protect way better. I resisted at first but once got Comfortable using them I'll
Never go back.
Never go back.
if your right about resisting those nasty spider swirl marks than that's a big plus. I hate those. I had my new 16 Jeeb SRT done with Cilajet. I'll check it out and see how it looks.
#33
I was taught at n early age how to detail like a pro. I just had my 2017 coated with Ceramic Pro. I would say that shine and the result when washing is slightly better than using Zanio (my best results to date). The difference between the Ceramic Pro and the Zanio is the Zanio will need a complete recoating 1-2 times a year and freshening every other time you wash the car.
The expense with having a professional coat your car is paint correction. There is two levels, buffing ($1000-$1500) and wet sanding to address orange peel (this can get very expensive, 3-4 times the $1000).
What you pay for with professionally applied ceramic coatings is paint protection and ease of care. My car has been washed twice and I have yet to touch it with a towel. Hose foam gun, hose rinse, blow water off the car. Now, I will have to towel the car but only about once every 3-4 washes.
#34
#35
The orange peel is bad in these cars and you're correct. It's not worth the effort or money to correct the orange peel. You can see in this pic by the sun light the peel is bad. I just correct the defects best I can and live with the orange peel.
#36
I'd have to agree. Reminds me when I brought my wifes c-class and the dealer offered a $300, interior protection. After some back and forth, I found out it was a can of scotch guard.
#37
I went with Feynlabs self heal lite. Not only is it nano ceramic coated. With a heat gun you can "heal" minor swirls/scratches
Here is a link to some photos of a recent scratch mod I had to remove
https://www.corvetteforum.com/forums...lly-works.html
#38
#39
Check out Adam's ceramic coating. They have vids on their site on how to correct and apply. You will need to decon, clay or nano, pain correction, polish and then apply coating. Use the boost after 24 hours. Don't bother doing it unless you prep properly of you will not be happy.
#40
