Mobil 1 oil filter vs AC Delco
#41
The "A" in the newly branded M1-113A stands for Annual Protection. They are guaranteed for annual protection when used with annual protection oil.
I would be willing to bet there is little to no difference between the 113 and the 113A other than a new sticker on the filter and new box that the filter comes in. Mobil has rebranded every one of their filters with the "A". Mobil does say that there is an "upgrade" in internal components to ensure the annual guarantee.
#42
From the Mobil website (regarding the "A" filter):
1. Upgraded performance – Structural components in the filter have been upgraded to help provide even longer-lasting protection.
2. Increased protection – The Mobil 1 Extended Performance oil filter now guarantees protection for one year or 20,000 miles, whichever comes first, and meets the requirements of the Mobil 1™ Annual Protection motor oil limited warranty.
3. New packaging – The Mobil 1 Extended Performance oil filter packaging has changed to be consistent with the appearance of Mobil 1 Annual Protection motor oil.
#43
However, it does make me wonder if AC Delco had to raise the bypass pressure because their filters are less efficient, or because the variable volume oil pumps require it? The variable pumps may be able to compensate for increase pressure drop and can still get the oil to the engine without bypassing.
#44
Mobile one produces the UPF any number R series for AC Delco.
given that the bulletin shows you can interchange the upf64r with a pf64 should be all the proof you need at the low pressure relief spring is the same it's just a better quality filter with an anti drain back and better sealing ring for higher Temps.
The Mobil 1 filter is constructed a little bit better then the UPF 64R butt they built the upf64r to GM AC Delco spec how they wanted to do it which probably save them a couple pennies for each oil filter therefore it has a bit lesser quality components but it's still above the non upfr series
#45
I looked this morning but couldn't seem to find what it's rated at. I did see the M1-113A filter is rated 99+% efficient @ >30 microns.
I found the Fram Ultra Synthetic (my current other favorite oil filter) bypass is rated at 9-12 psi. The regular Wix and Wix XP are 12 psi.
It appears that none of these aftermarket filters are anywhere near the 22 psi of the ACD PF64.
#46
I just emailed Mobil's technical support so we'll see what they respond with.
#47
On the M1-113a box it also says....
"All new car warranties remain in effect when Mobil 1 oil filters are used for vehicles covered by a warranty. Follow the vehicle's oil life sensor or oil change interval recommendation in the owner's manual. See product for country of origin marking."
M1-113 says...
"All new car warranties remain in effect when Mobil 1 oil filters are used. Follow your vehicle manufacturer's recommended oil change intervals"
The box of the M1-113a says "Protects for up to 1 year or 20,000miles whichever comes first. The box for the M1-113 says ""Up to 15,000 miles of Guaranteed protection when combined with Fully Synthetic Motor Oils".
The 2017 Corvette owner's manual says to change the oil and filter every 7,500 miles, if needed.
M1-113 says...
#48
I called the Mobil Oil Filter Hotline a month or so ago. It is answered by Champion Labs who manufactures the Mobil 1 and PF64 filters. The bypass rating at that time for the M1-113 was 17 psi and the PF64 22 psi according to their tests. I did not ask about the M1-113a as I had not seen that designation at the time.
As to the statement by 16/C7Z that Mobil produces the UPF, that is not true because Mobil does not make filters. The UPF is likely manufactured by Champion Labs who makes the Mobil 1 filters.
Champion Labs was very willing to discuss details when I spoke with them.
The Mobil 1 and PF64 both meet the GM minimum bypass specification of 15 psi while the PF64 is higher than the minimum at 22 psi.
The Wix and Fram as stated in a recent post apparently do not meet the specification as they are rated at 12 psi.
#49
Thanks for asking the source.
https://www.consumer.ftc.gov/article...ne-maintenance
Since I believe that the Mobil1 oil filter is a better filter than the ACDelco PF series filters, I will continue to use them on my LS7.
#50
This pretty much answers things, and makes me comfortable continuing to use the M1-113 in my C7.
#51
There again, it may be the WIX is more efficient and can still flow the required amount with less pressure drop.
#52
Looks like I can use my remaining stock of M1-113 that I was using for my ZL1
Side note;
Dorman 097-119 Oil Drain Plug Gasket (sub for GM 12616850)
$.79 at O-Reilly's, but since Auto Zone was closer, I went there and they price matched (reg. price $1.19)
Maybe other Auto Parts Houses have a price match policy too...
https://www.oreillyauto.com/detail/dorman-autograde-3358/filters-16470/oil-drain-plug-gasket-12112/drain-plug-gasket/097119/4177632/2017/chevrolet/corvette?q=.097-119+oil+drain+plg#compare=4182445&compar e=4177632
Side note;
#53
Received 5,217 Likes
Excuse me if this is here somewhere and I missed it, but what filter does the LT1 ship with from the factory, please???
#54
E-Ray, 3LZ, ZER, LIFT
Received 9,626 Likes
That pretty well answers the question as if Mobil1 filter meets GM specs and that they can't refuse to honor their warranty.
What I referenced is the car mag (perhaps it was Car & Driver) that had a C7 engine failure during a test that was attributed by GM to an oil filter failure. It was the original OEM PF64. Also some years ago there was an engine failure attributed to a Fram filter discussed in detail on the Forum.
My premise is, if the unlikely occurance of an engine failure due to a PF64 DELCO filter, GM would still have to cover the failed engine while my Grand Sport is covered on warranty. If the failure was clearly attributed to a failed Mobil, Fram etc filter GM could not be expected to cover the engine failure regardless of it "meeting" a GM spec but was defective. "'Just Say'n."
Don't get me wrong, I think most filters are just fine and filter the oil as much as I need. I change it each year in my Street Rod with few miles and use a Fram filter. In fact Fram is the only one I found with a filter short enough to fit with the long tube Sanderson headers in that 8.2 Liter BB!
#55
The following 10 users liked this post by Kracka:
Foosh (04-03-2018),
GM'er (10-19-2017),
HorsePowerObsessed (03-29-2018),
JoesC5 (10-19-2017),
Patman (10-19-2017),
and 5 others liked this post.
#58
The debate is whether the base mounted bypass helps minimize crud released to the engine in the event it does bypass.
#59
Do you have a schematic of the filters to validate what you are saying? Since they are both made by Champion Labs, I would guess, and it is a guess, that the construction is very similar with differences possibly in filter material, gasket material or other nuances to meet the specification of Mobil or AC Delco. The box the M1-113A came in that I purchased this morning showed the anti-drain-back at the top, but it did not show the baypass.
#60
