zl1 Pucks came in. Where to put them ?
So there are several locations for jacking and I have my leave in pucks. I will be using a lift to change my oil and will be using the lift points most frequently BUT, There are the other points which could be used in an unforseen circumstance. Do the frame points even have the opening for the pucks ?
They can only go at the 4 blue locations in that photo.
The areas in red are only ares for jack stands, or with a spreader bar with lift pads at those locations and a jack beneath at the spreader bar center. Then you would put jack stands along the frame rails at the blue indicated locations.
Krenath (07-31-2017)
