Wheel Spacers - AMT Motorsport - FREE SHIPPING
Premium Supporting Vendor
St. Jude Donor '07-'08,-'13-'14, '16-'17
AMT Motorsport
C7 Corvette
Wheel Spacers
Sometimes only the best will do, and Wheel Spacers is one of those
times. AMT Motorsport Wheel Spacers are Milled to 0.0005 tolerance
and only weight 1.0 and 1.2 pounds each. Improve the stance and
lower the center of gravity in your C7 Corvette with a set of Hubcentric
3/4" or 1" Wheel Spacers from CCA and get FREE SHIPPING in the US
or
Choose from the New 1/4" and 3/8" Wheel Spacers
AMT C7 Corvette Wheel Spacers
Regards
Chip
Do you haveany before and after pics?
ZorenZ51 (07-31-2017)
Hi Chip, I'd like to bump this thread to see how your spacers look on your GS. I have a AW GS already dropped on factory bolts. Would be very appreciative to see how your looks with your spacers.
Will post up picks
It may be a month or so, I am traveling between VA and FL weekly
to help out with my Dad. Seems like if I'm not working or with him,
I'm on a plane...
Regards
Chip
Pics courtesy of E. Bencosme
Regards
Chip
Hey there
quick question. I think I know the answer to this but
if I was to install spacers would I need to upgrade to a longer wheel bolt?
and, do you sell those too?
thank you.
thank you.
For SURE 3/4"-1"
Personally recommend for the 3/8, but not required
The 1/4" you do not need longer bolts...
Here are the 3.25" studs
https://www.corvettepartsandaccessor...heel-hub-studs
Regards
Chip
