Battery tender
Battery tender
You would think they would have a hole to get the battery maintainer into the back without having to leave hatch up or one where you could pull a plug out to get it up into the hatch area? Thanks
I have winter stored my 2016 Stingray with battery cable and trunk lid closed. No issues.
The following 2 users liked this post by capecodvette:
JDM111er (08-08-2017),
Rebel Yell (08-07-2017)
Like Cape Cod Vette said you can close the hatch/trunk on the wire. It will not hurt the car or the wire. I have done it for years and I had a coup and a vert! I store for winter so it sits that way for at least 5 months!
rodney123456 (08-07-2017)
No hole necessary:
The following 2 users liked this post by millpond:
rodney123456 (08-07-2017),
vbdenny (08-07-2017)
Received 3,288 Likes
St. Jude Donor '12-'13-'14-'15-'16-'17
No hole is needed, and leaving a hole where water or exhaust gas could potentially enter the vehicle is a very bad idea.
plugging it in and closing the trunk is not hard. But maybe there is an easier way to to it by NOT having to open the car up in any way.
IE. a quick connect run underneath the car somehow
How is running wiring and having a disconnect underneath the car easier than opening the trunk or hatch?
Don't try to solve a problem that isn't really a problem.
The following 2 users liked this post by Steve_R:
Boiler_81 (08-08-2017),
joemessman (08-07-2017)
If you keep your car in a garage that's out of the weather and away from unauthorized tampering you may want to just keep the hatch ajar. After ~20 min. the ECU puts the car to sleep and lights and other functions are extinguished. I've done that for my previous and current C7s, as the tender is connected at all times in the garage.
Received 2,046 Likes
St. Jude Donor '13
There was an item for the C6 that used a magnet to connect the tender wire near the front grill, so if you forgot to unplug then it just disconnected itself as you backed out of the garage. Super easy to attach or disconnect, of course.
Not sure if they make a C7 version, or how difficult it would be to use the C6 version.
I have been closing the truck lid and worry about backing my GS out of the garage and forgetting the maintainer is still attached. I think leaving the hatch slightly open is a much better idea as the DIC should tell he the hatch is open - thus reminding me of the maintainer being attached.
Going to the garage now to open the hatch slightly.
Pit Now (08-11-2017)
I've gotten good at backing the C7 into the garage with the truck present, and can do it as fast as coming in front first.
St. Jude Donor '13
Since our C7 is a semi-daily driver, the tender isn't connected every day.
When it is connected, I plug it into the wall near the front of the car and use a long slender (less likely to trip) extension cord to the rear. The extension cord lays on the floor going past the driver door, so that's my reminder to remove the tender and put it back on the shelf at the front. So far, it works.
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes
2015 C7 of the Year Finalist
I use the magnetic connector that I had on my C6 on my C7. Hood, doors, and windows stay closed.
http://www.ls2.com/forums/showthread...hlight=battery
Elmer
Elmer
For my purposes the rear lighter connector on the C7 works best, but if you want to connect via the engine compartment I would go with Eboggs' elegant solution.
