Possible Move North
Yeah, the Sioux Falls winters can be challenging, but you're moving to one of the most tax-friendly states in the USA, populated by friendly, self-reliant folks. Whatever you do, stay the hell out of Minnesota, known as "The Land of 10,000 Taxes" -- and that's not much of an exaggeration. I'm a native (for now), and I know.
Received 1,609 Likes
St. Jude Donor '16-'17,'22,'24
For several years I had a job where I spent one week a month in Baudette MN. You're right in that they had industrial strength cold up there. The coldest I experienced was -39F. Trust me, that's cold. I know there is at least one auto development test track up there, possibly two used for cold weather testing and some GM cars are tested there. We used to make jokes about the weather. My favorite is, They have two seasons in Baudette, Winter and July.
Sioux Falls is a little further south which doesn't sound like much, but it really does moderate the cold.
I didn't really do anything to my car last year. Gave it a bath and fired up the battery tender. I usually change the oil in the spring because I'm less lazy in the spring. Car sleeps fron 12-1 to 4-1. Was nice enough to use it right up until Dec last year if I recall.
I'm from Saskatchewan. I'd assume the climate is kinda similar, which means your car comes out in maybe late April and goes back into storage in October or so. You'll get plenty of advice on how to -store- the car, the harder one is "How do you make payments for 7 months a year while the car is in storage!"
The only good news is that every spring, getting the car out is like getting a new car. So you get the visceral thrill of a new car every spring!
Virtual Geezer (08-16-2017)
Received 8,918 Likes
There is a new recommendation on the gas tank when storing to fill only 1/4. The reason for only storing with 1/4 tank of gas has to do with the location of the fuel sending unit. In the C7, the fuel sending units are half way up inside each of the two tanks. Sulfur in the gasoline can coat the fuel level sensors, causing the fuel gauge to become inoperative. The reason that this does not happen when you are regularly driving the car is that movement of the gas in the tanks keeps the contacts clear.
Bill
I grew up in Florida and have lived all over including Minnesota for 7 years and now New England. Minnesota winters can be tough for a couple of months, but the spring, summer, and fall seasons are so nice. It's 78 degrees here today and 95 degrees where I lived in Florida.
No thanks. I will put up with a couple months of snow but then enjoy the spring, summer weather.
Bill
E-Ray, 3LZ, ZER, LIFT
Received 9,605 Likes
Even though I mostly use Top Tier gas, the GM product and Techron indicate they help dissolve sulfur deposits. All oil has sulfur, some quite a bit. Most gets refined out but not all! Top Tier has nothing to do with sulfur levels and it does contain additives to help reduce deposits. But if the senders get coated, replacing is a major operation! The drive train is dropped to get the two tanks out!
A poster who's C7 senders were operating erratically had a dealer put two containers of GM fuel additive in his tank and fixed the issue. Charged him ~$100 as I recall. Adding one container (~$10) at each oil change is cheap insurance, IMO.
joemessman (08-16-2017)
Received 3,439 Likes
Hi Bill. This is what the corvette engineers have stated. I just pass on the information. I'm certain they wouldn't make a statement without a basis. But then again these are the same guys, gals that can't seem to cool Z06 to proper temp going around a race track, or solve the issues surrounding the A8 transmission. I,m not sure where specifically the sending unit is housed. But they say if your gas gauge is at one quarter or less, the unit is not submerged in gasoline.
Definitely less snow last year. I got a kick *** snow blower last year and was actually kinda bummed that I only got to use it a couple times, and one of those was just a 4-5" dusting where I had to at least try the thing...
#33
My in-laws in Sioux Falls have commented the last two winters have been milder than usual and not much snow. So there may be something to this "Global Warming" stuff as it is just plain brutal in Central FL this summer.
#34
Received 2,186 Likes
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15- '16-'17-‘18-‘19-'20-'21
NCM Lifetime Member
No Ice
It is much warmer without question. We've had no ice storms the past two winters here in the Dallas area.
#35
Received 4,689 Likes
Yep, I can help you with storage questions, I do use Stabil stabilizer in my tank... pour the required amount in before you drive the car for the last time before storage along with fresh fuel bought that day & drive the car for a few miles to get the mix into the entire system. Buy a battery maintenance charger & leave it plugged in the entire time the car is in storage... change the oil also.If you are storing the car in a unheated area, make sure the coolant is fresh. As far as people saying that the tires get flat spots, I have never had this happen to me & I store my car from Dec to March. If you do this, your car will be ready to go in the spring
#39
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,810 Likes
2015 C7 of the Year Finalist
Send the wife north and you stay in Florida. Best of both worlds!
Elmer
Elmer
