Tire has chunks of rubber
Bit the bullet & got new Ps2's.
Tire shop took off olds & they did not have pickup marbles, but, chunks out of all 4 tires.
No way would this have worn off.
Thanks again for all the comments.
Received 1,029 Likes
St. Jude Donor '05-'06-'07-'08-'09, '14-'15-'16-'17-'18
Wait a minute. Do you mean that chunks of rubber from your tires were missing? Not talking about the rubbery goo that adhered onto your tires...
Received 2,221 Likes
No photo?
Ques?
305's were rubbing fender lip ( car is lowered)
Raised it up , no fender rub, but, one side rubs on the fabric fender liner on a bump in the liner. Only passenger side.
Tried pushing it in, not sure this will work.
Any suggestions, cut a hole in the liner?
Received 2,478 Likes
St. Jude Donor '15
"In honor of jpee"
If you meaning lowering and rubbing, doesn't seem so since he said in #22 "...but, chunks out of all 4 tires." And only one was rubbing.
Don't know why the original PSS's chunked.
As for the new 305 rear rubbing.
Was the drivers side rubbing rear plastic liner rear area.
Heat gun & lever to push in liner.
Worked & no rub.
Off to the Convention next week & running.
Worked & no rub.
