The dreaded intake whistle!
Of course I did all bolt on mods at once so I'm not sure which one is causing the boosted whistle sound when applying some decent throttle.
Some say it's the ported manifold along with more air flow. A lot of theories out there.
All I know is that it's annoying and must be eliminated. lol
If anyone has any experience with this and/or proof of a definitive solution please share.
I just installed:
CAI
ported stock manifold
ported TB
Thanks,
Rob (owner of a whistling vette)
I just installed:
CAI
ported TB
Thanks,
This may be a question better asked in C7 Tech forum.
I just installed:
CAI
ported TB
Thanks,
I just installed:
CAI
ported TB
Thanks,
The CAI eliminates the air silencer. All intakes whistle without a silencer.
I came across something like this on a Grand National which drove the owner nuts. High pitched whistle on acceleration. It turned out to be a loose clamp on his air intake duct. This may not be the case in your situation, but worth a quick check. And also, the clamp looked like it was tight, but a couple of turns tighter and the noise went away. Just saying. Good luck.
Glad you found the issue. As I recall, we ended up smearing the insides of the hoses with some silicon and letting it set overnight and it completely stopped the engine from making that noise. Good luck with the fix.
Received 3,818 Likes
Good example of this forum at its best. No bitchin', just fixin'. Great job!
