Z51 discontinued for 2018?
#41
exactly---near perfect Vette for me is Z51 w/ mag ride & Z06 engine only(don't need--big spoiler, bigger rims, extra scoops, wide body or any additional aero trim) but might pay extra for Recaro or other "special" seat option.
#42
Newer always sells more. It's called pent up demand. This is the reason GM has a staggered launch of various trims, because it keeps the factory humming.
That's economics, and really doesn't give you an accurate representation of the market. You have to take all sales between 2014 and now to make any sort of comment on popularity (and in all fairness you need to wait until the model is no longer on sale).
Z51s make up less than 14% of total 2017 production.
#44
Stingray Coupe, 11,253, 34.30%
Stingray Convertible, 2,298, 7.00%
Grand Sport Coupe, 9,912, 30.20%
Grand Sport Convertible, 2,046, 6.20%
Z06 Coupe, 6,197, 18.90%
Z06 Convertible, 1,076, 3.30%
Totals: 32,782
spireland (08-23-2017)
#45
Yes, and the GS was a new model in 2017, no big surprise. That's exactly what we're saying, it's the latest new thing. Clearly the GS cannibalized a lot of Z51 sales since the GS is essentially a Z51, with wider body panels and wide tires. Overall, Stingray still outsells GS 41% to 36%.
#46
Uh, I think we're violently agreeing. Yes, was popular as a new model for 2017, but like all new models, it's all downhill from here.
#47
E-Ray, 3LZ, ZER, LIFT
Received 9,619 Likes
FWIW, those who have a Z51 justifying why it's better is a bit of a stretch!
I conceded the narrow body look is fine but there is a reason Car and Driver and others rate the Grand Sport as the best overall performance.
I won't list the 0 to 60 times as it is very driver dependent and I don't care as I have an M7 so an automatic will beat me any day of the week!
However look at the Lateral "g" and braking data.
Now this is not a statistical average of every published report but does closely match what one mag got for both cars:
Lateral "g" : Z51 = 1.03/1.04; Grand Sport = 1.19/1.20
60 to 0 braking: Z51 = 101 feet; Grand Sport = 90 feet
Just Sayn' so the vocal minority doesn't outweigh real data in this Thread!
#48
I didn't hear anyone saying it was better, or justifying anything, just that we preferred the look, and it has certain advantages for street use like tire availability and costs less.
#49
However, there are many people who much prefer the narrow-body look, but want the performance equipment. The Z51 still sells well, plus you can actually get UHP all-seasons for it and drive it year-round.
For an identical price, I'd still choose the Z51 over the GS for daily driving duty.
Non-Mag ride z51 works for me better as a daily than the GS. If I was going for a garage queen a GS would be a lot more fun but saving a few bucks, less money for tires, just works for a car I'm using on a daily basis.
#50
That was my biggest complaint about Grand Sport, it was REALLY hard to find any reviews done on a regular Grand Sport, it was all done on Z07 equipped cars. That would be ridiculous for a daily driver.
#51
Even the cf rotors are supposed to be better for tracking because they don't overheat but not sure they stop any faster. It's true most car mags got the Z07 to test. If I were GM that is what I would provide as well!
#52
Nope standard brakes. Check Motor Trend they tested both with similar numbers. Yep track number would make a difference but not so much for lateral "gs" or braking. Speeds are slower so aero is not a factor.
Straight from Brembo.
"If all of this doesn't seem to be enough, don't worry, there is always the Z07 Performance Package: along with the Michelin Pilot Sport Cup 2 tires and a Z07 suspension that guarantee the possibility of taking turns at 1.2g (1.05g with the standard model), there is a more advanced braking system, also signed by Brembo.
Instead of discs with a cast iron braking band, the Z07 package uses larger, carbon-ceramic discs: 394 mm (38 mm thick) on the front and 390 mm (32 mm thick) on the rear. This makes for a considerable weight reduction: the braking system on each front wheel goes from 10.87 kg to 6.2 kg, with a 43 percent reduction, whereas the rear, also per unit, goes from 11.3 to 8 kg with a 29 percent reduction. This is a light weight that translates into quicker acceleration, shorter braking distance and even lower fuel consumption."
http://www.brembo.com/en/company/new...-brembo-brakes
LT1 Z51 (08-23-2017)
#53
Have a Grand Sport and read quite a bit! The issue is they stop better when tracking and are hot as they get better and have zero fade.
Bet I'll beat one on my cold pad stop I do every day with my Carbotech 1521's! Had those on my 2014 Z51 and now on the larger Brembo calipers on the Grand Sport with fatter tires stops even faster. It you're tracking fine, agree with the Brembo marketing blurb!
#54
I'd bet if you can get the Grand Sport wheels and tires under a Z51 w/Mag Ride, the numbers would be identical (non Z07 GS).
0-60 and lap times could even favor the Z51, due to a possible lower curb weight. I'm sure that making the GS fatter also added some sprung weight to the mix.
#55
I pointed out that's because of the z07 package.
Not sure why you think the OEM Brembo isn't a valid source, because the info does back up, the GS is 1.05 in stock form....which is basically the same as the 1.03 you listed in your post for the Z51.
The GS is a great car. It's just not a night and day difference from a Z51, in stock form.
#56
Corvette Enthusiast
I don't know how to make this clearer.
#57
Corvette Enthusiast
All the magazines test with the Cup 2's, this is why GM offers them.
If you want an honest look at how much Cup 2's can change a car look at the GT350 and the GT350R (Mustang) numbers. The R only has 4 changes, 1. carbon fiber wheels 2. Cup 2 tires and 3. a carbon fiber wing 4. a larger front splitter, it basically proves aero + sticky tires = faster.
#58
Corvette Enthusiast
Again, see my previous post visa vie the Mustang GT350 versus the GT350R
#59
But even my Grand Sport came with camber set at the high end of the broad GM spec. On average -1.6 camber.
#60
You said how amazing the GS was because of it's skid pad G rating, on a track...... now the tracking stats are pointless?
Decided to crunch some numbers on the Brembo info that sounds dramatic the way they present it; 43% and 29% rotor weight reduction for which they attribute all types of benefits related to the reduced Rotational Inertia!
Sounds good but the Rotational Inertia is proportional to the mass and the radius squared where the mass can be consider concentrated. Yep rotor weight reduction is ~9 pounds per their info. Calculating the rotor weight and effective radius, the Tire weights of 30 and 34 pounds and effective radius-much further out. Doing the same for the 26/28 pound wheel weight and estimating where that weight is positioned I get Rotational Inertial Values. Comparing both values yields a Rotational Inertia reduction of 4.2% with the carbon ceramic rotors. Not as dramatic!
As I said, if tracking worth the cost but I'll take my Carbotech 1521s for making quick stops on cold pads that I make several times per day when I leave my home and enter a 4 lane divided highway. After merging into 65 mph traffic I make a turn onto another rural road in less than 100 yards! I slow for that turn with very high "g" braking to avoid anyone behind me from having to hit their brakes!
