GS key FOB submerged in vinegar H2O
Old 09-14-2017, 02:13 PM
Heidemarie
Heidemarie's Avatar
Default GS key FOB submerged in vinegar H2O
Need help; can anyone recommend how to dry out FOB that was accidentally submerged in water that had vinegar added to it. Took key out very quickly, but the inside of FOB was wet. Dried out with hairdryer but still can smell vinegar. Worried that the vinegar will corrode inside of FOB.
Question:Anyone have remedy to prevent corrosion? Certainly do not want to re-submerge FOB in regular H2O to remove vinegar smell. BTW: To my surprise FOB still starts vette after all this.
Heidi
Save the Wave
Old 09-14-2017, 02:45 PM
DanZR1
DanZR1's Avatar
I've sent them through the washing machine, and jumped in the pool more than once. They are amazingly water tight. If it was me, I'd just rinse it off, and let it air dry. If you want to go OCD on it, unsnap the two halves, take the board & battery out and set them aside. Wash the plastic pieces, let them dry and put it back together. Go easy with the hair dryer, excess heat will do more damage than water...
Heidemarie (09-14-2017)
Old 09-14-2017, 02:47 PM
dmaxx3500
Support Corvetteforum!
dmaxx3500's Avatar
Received 1,183 Likes on 748 Posts
get the battery out,wash with ''windex'' let dry and re-assemble
Old 09-14-2017, 02:52 PM
Zymurgy
Moderator
Zymurgy's Avatar
Received 15,075 Likes on 6,173 Posts
Baking soda is a weak base that will neutralize acids giving off carbon dioxide. But I don't think I'd want to stick it into baking soda. Less drastic would be to stick in it some uncooked rice for 48 hours. The rice will absorb any remaining moisture.
Old 09-14-2017, 02:56 PM
CCA Corvette Parts
Premium Supporting Vendor
CCA Corvette Parts's Avatar
St. Jude Donor '07-'08,-'13-'14, '16-'17
Rinse with water and stick in white rice for a day or two
Regards
Chip
__________________
..................Click for
Old 09-14-2017, 03:27 PM
Heidemarie
Heidemarie's Avatar
Regards
Chip
Thanks; does it need to be "white" rice? Can I use black Heirloom Forbidden Rice (that's the only kind I have at home)? Any Idea?
Heidi
Old 09-14-2017, 03:33 PM
CCA Corvette Parts
Heidi
Sorry, can't say if it will work. Worth it to get white rice, it only $2
and it for sure works
Regards
Chip
Old 09-14-2017, 03:57 PM
Patches
Patches's Avatar
I use this type of cleaner for boards, connectors, etc.
Old 09-14-2017, 04:05 PM
trivette
trivette's Avatar
My fob went through the wash following my Road America trip. (I'm still not used to taking the damn thing out of my pocket, I guess)
I dried it and replaced the battery. It worked, but the battery only lasts a couple of days (I tried another one as well) so some damage was obviously done. Must be constantly searching for a signal or something causing it to drain.
Old 09-14-2017, 04:31 PM
NSC5
NSC5's Avatar
Received 1,100 Likes on 742 Posts
Remove and discard battery then distilled water rinse followed by bag of rice or other desiccant material.
Old 09-14-2017, 04:40 PM
DanZR1
DanZR1's Avatar
FWIW, rice will absorb moisture, but you take the chance of getting a broken grain of rice & rice dust in the fob. I dunked an iPhone about 6 months ago, and after a bunch of Googling, I found many articles advising against using rice. Just my $0.02...
Old 09-14-2017, 04:53 PM
2K14C7
2K14C7's Avatar
C7 of Year Finalist (stock) 2019
2018 C7 of Year Finalist
You could also use WD40. The WD stands for water displacing. Then blow it dry with some canned air.
FLATJ (09-14-2017)
Old 09-14-2017, 05:09 PM
Zymurgy
Moderator
Zymurgy's Avatar
Intel recommends using rice. Hard to argue with the one of the worlds largest microchip companies. Intel Technology Tips
The following 2 users liked this post by Zymurgy:
Heidemarie (09-14-2017), Strake (09-14-2017)
Old 09-14-2017, 05:20 PM
NSC5
NSC5's Avatar
Or remember those little packs of desiccant that come packed with most new electronics products, the ones that advise you "do not eat" ? I guess it is time to start saving them for use in saving fobs, phones, etc. Putting the desiccant pack in the sun on a dry day will drive out the moisture then put them in a sealed bag for future emergency use; they can also be baked but I would use caution there because you don't want to put them in a regular oven.
As 2K14C7 noted WD40 will work but it can leave a messy residue behind that you will need to wipe up. I have used it quite often in electronics work to clean things. It is primarily a light distillate of petroleum with some light oil added and the oil will remain after the other parts of the mix disappear. WD40 isn't conductive but it is highly flammable and in times past some people used it to help start a diesel engine as a less explosive alternative to ether but not a good idea with diesels that use glow plugs and/or intake grid heaters.
Old 09-14-2017, 05:40 PM
joemessman
joemessman's Avatar
Received 3,439 Likes on 2,059 Posts
GM recommends removing the battery, let air dry for one week. If it is liquid besides water, rinse the Keyfob after removing the battery and let air dry one week. Replace the battery after a week. Start the car. If not working? Buy new Keyfob. Don't ask me how I know. Mine did work following those instructions. I dropped it in the toilet.
Old 09-14-2017, 06:04 PM
Bill Dearborn
Bill Dearborn's Avatar
Received 8,926 Likes on 5,332 Posts
The problem isn't water it is acidic residue. He is trying to reduce the impact of the acid in vinegar. Flushing with a good safe electronics cleaner is the way to do that.
Bill
The following 2 users liked this post by Bill Dearborn:
Old 09-14-2017, 07:03 PM
DanZR1
DanZR1's Avatar
Other tech sites disagree.
https://smartphones.gadgethacks.com/...phone-0154799/
Besides not really being effective, getting a swollen up piece of rice stuck inside your phone (or fob) ports is probably not a good thing. I'd not try it, as it makes sense to me. I'm sure we could both Google lots of data either way. Because internet...
To GS key FOB submerged in vinegar H2O
Old 09-14-2017, 07:54 PM
Heidemarie
Heidemarie's Avatar
Thanks; WOW yours sounds worse!!!!!LOL
Heidi
Old 09-14-2017, 08:44 PM
Grand Slam
Grand Slam's Avatar
As others, mine has been through the was a couple of times. I just took it apart, wiped off all the parts, left in the sun for a couple of hours to dry and assembled it again. Works like a charm.
Heidemarie (09-15-2017)
Old 09-14-2017, 08:54 PM
owc6
owc6's Avatar
Received 4,186 Likes on 2,679 Posts
Check to see if a button is stuck, because the fob doesn't search. If it's still using battery noticeably, then you have a connection still active in the fob (whether it's a button, or a circuit that has corroded and made a connection).
Quick Reply: GS key FOB submerged in vinegar H2O
