A8 indicator of V4
A8 indicator of V4
Is there a way to tell when the A8 transmission is in V4 mode with an icon etc? Also does it go into this mode only when in 8th gear or in all gears depending on your pedal pressure?
Popular Reply
09-15-2017, 10:54 AM
From my experience with a few thousand C7's being serviced and sold. The A8 problem is being way overblown. In my opinion, the failure rate on them is no more than any other retail product being sold today. but if you come on the forum, you may never want to buy a Vette with some of the things you see and hear.
The following 4 users liked this post by hangman:
It goes into V4 pretty much any time you're moving without a load on the engine (i.e. - constant speed cruising). I know the indicator is displayed on the range/average fuel economy DIC info screen, but not sure where else.
Kev4 (09-14-2017)
Kev4 (09-15-2017)
There is a lot of confusion surrounding this cylinder deactivation process and the dealers are all but worthless. I asked TWO dealers the following simple question: Does the cylinder deactivation occur in ALL modes or just ECO? They had no clue. From owner feedback on this forum, it sounds like it is not specific to a drive mode, it simply reacts to throttle response combined with gear setting. Of course the manual mode blocks cylinder deactivation. With that said, I think Chevrolet dropped the ball BADLY. I would think the cylinder deactivation would only work in the ECO mode. If you are going for a long interstate drive and switch it to ECO, then it would make since to run on 4 cylinders at cruising speed. But in Touring or Sport mode? Not so much. I know people are using the Range module to bypass this process, but they seem to have their own set of problems. This is probably the biggest obstacle to me buying a new Grand Sport.
Why would you allow something so simple to deter you from buying an amazing car? If AFM ends up irritating you, just disable it. Or, buy a M7 and that way the car only uses V4 while in Eco mode just like you want.
Kev4 (09-15-2017)
Simple? Have you seen the number of problems with the A8 transmission reported on this forum in regards to the AFM? Sorry, I don't think having a TC or transmission go bad on a 70K car is "simple".
Buy the M7 then, it's a great transmission; I had zero issues with it, or running in Eco mode on numerous cross-country roadtrips. If you want the A8 though and are worried about AFM, just disable it...or let the warranty do its job and not worry about a thing.
Yeah, I probably used the wrong term about buying a new GS. It's not an obstacle, just a concern. However, the percentage of people having problems is far fewer than those not having problems at all, so I am probably just being a little crazy. I would love an M7, but I want to make it enjoyable for my wife to drive, so we will probably just go with the A8. I will step off my soap box now.
Gonzo (09-15-2017)
I'm sorry nobody could help you. Next time you have a tech related Corvette Question, etc. Please don't hesitate to reach out to me. I may be in competition with other dealers for sales, but I am here to help each and every Forum Member and Corvette Owner that has a question. Enjoy your Day and Save the Wave!!
Gonzo (09-15-2017)
The following 8 users liked this post by KennyG MacMulkin:
beaversstonehaven (09-16-2017),
birdsong (09-15-2017),
bsterling9 (09-15-2017),
Carvin (09-15-2017),
Gonzo (09-15-2017),
and 3 others liked this post.
Page 204 of the 2017 manual says "With manual transmission: Active Fuel Management only active in Eco mode". So I read that as if you have an A8, it is active in EVERY mode. Never does it explicitly state that it is available in only one mode, that section starts off describing what it does and says it is a normal function and it "changes to 4-cylinder mode when coasting"
This is from the 2014 Owners Manual:
Normal with automatic transmission: The engine uses 8-cylinder mode when accelerating, but changes to 4-cylinder mode when coasting.
With manual transmission: Active Fuel Management only active in Eco Mode.
Active Fuel Management (engine cylinder shuts off)
4-Cylinder Mode
Off in Manual mode with automatic transmission unless in Eco mode.
Eco keeps the engine in 4-cylinder mode unless heavy acceleration is needed.
4-Cylinder Mode
Gonzo (09-15-2017)
